Suspension & Brakes Theory, alignment, spring rates....
Skunk2 pro c series
Old Aug 12, 2009 | 12:52 AM
HondaTeKnology's Avatar
Icon2 Skunk2 pro c series
I wanted to kno if Skunk2 pro c series coilover system is any good for a daily driver.
Old Aug 12, 2009 | 07:58 AM
dandaman15's Avatar
Community Builder
Default Re: Skunk2 pro c series
http://lmgtfy.com/?q=skunk+2+pro+c+review
Old Aug 12, 2009 | 09:25 AM
Flint707's Avatar
I love mine. Went from Tein SS to Skunk2 Pro C and I'll never go back. Night and day difference (Skunk2 prevailed).
Old Aug 12, 2009 | 10:22 AM
Egezzy's Avatar
Spongebrad Squarepants
my buddy rides dumped as ffck on them and doesnt ride bad at all.
Old Aug 12, 2009 | 11:47 AM
thanks for the response guys. All Ive been reading about is Koni yellows with GC.
Old Aug 12, 2009 | 12:02 PM
Flint707's Avatar
I'll take a full coilover over a shock and sleeve coilover any day of the year.
Old Aug 12, 2009 | 12:40 PM
racebum's Avatar
the pro c has one advantage over the yellow/gc combo and that is the ability to go down without touching preload. if you're one of those guys who thinks riding dumped is cool, this is a major benefit.
as for other stuff. every time i hear "i'd rather have a TRUE coilover" over the koni/gc i normally picture someone who's never had either. all something like a tein ss coilover is, is a threaded shock with an adjustable perch. i mean, do they get kudos for fixing the thread body in place? it's really no different of design from the koni/gc
Old Aug 12, 2009 | 12:55 PM
Flint707's Avatar
Actually yes, they do get kudos for having the threaded body in place. Like you mentioned... having ride height and preload adjustments separately is kind of a big deal (for some folks). Also, the Pro C's have a fixed valving... so you can run up to an 18k spring and be fine. More kudos for that option as well!
Old Aug 12, 2009 | 01:29 PM
racebum's Avatar
that's kind of a shotgun answer. i agree that it's a perk on something like the pro-c but the tein ss for example is also called a "true coilover" and it's nothing more than a gc style sleeve fixed on a shock.
both the konis and the skunk c's are adjustable. not sure what fixed valving means since neither are.
Old Aug 12, 2009 | 02:50 PM
Flint707's Avatar
Since neither are? The Skunk2 Pro C's do have a fixed valving. Most other manufacturers require that you have the shock re-valved accordingly to your spring of choice.
Like I mentioned previously... the Skunk2 valving is good for springs up to 18k right out of the box.
Old Aug 12, 2009 | 04:50 PM
TunerN00b's Avatar
A fixed valving means that they are only valved for one spring rate. Anything else is either over or under damped.
Adjustable valving means the user can adjust to suit a range of spring rates.
tduzzle
Suspension & Brakes
Aug 1, 2008 11:10 AM
davidofazrael
Apr 28, 2008 06:49 PM
DC4 Rasta
Suspension & Brakes
Nov 19, 2007 12:36 AM
Like Butter
10
May 10, 2007 09:51 AM
