thump noise on passenger side
Old Aug 11, 2009 | 03:53 PM
immajackuup's Avatar
Default thump noise on passenger side
Everytime i make a really hard u-turn to the left i get this thump or when i revers going at a angle than move forward.
It only happen here and there not all the time.
Motor mount are good but bottom two side are crap,ball joint seem to be good because it doesn't squeak or show sign of grease gushing out,swaybar is tight on.
Wtf can it be?
my steering wheel does shake at idle so I assume motor mount is going bad but it seem to be good.
Old Aug 12, 2009 | 04:03 AM
Default Re: thump noise on passenger side
bump
Old Aug 12, 2009 | 06:50 AM
shoklid's Avatar
grab ur wheel at the top move it into and away from car if noise occurs upper control arms ball joints
Old Aug 12, 2009 | 09:30 AM
famou55TAR's Avatar
well if you have bad mounts replace them.
Old Aug 12, 2009 | 09:39 AM
EL Vap133's Avatar
Could be bad mounts, could also be a bad shock/strut.
Old Aug 12, 2009 | 10:20 AM
bkopel805's Avatar
bad ball joints?
Old Aug 12, 2009 | 10:21 AM
gonnda try that later
the motor mounts look good no crack or so but my steering wheel does shake at idle.
i'm kinda leaning toward the mounts,can't be strut because my dampers are working fine.
Old Aug 12, 2009 | 11:02 AM
well i don't think is my balljoint because i can feel the thump through the pedal so yeah i think motor mount went to ****.
but I don't see no crack or tear the mount,this suck *****.
Old Aug 13, 2009 | 06:00 PM
can swaybar move around??? like side to side.
Old Aug 13, 2009 | 06:01 PM
jkalex05's Avatar
Have you checked the cv joint?
Old Aug 13, 2009 | 06:41 PM
TwoKSiR's Avatar
x2
Old Aug 13, 2009 | 06:47 PM
cv is still good no boot tare or clicking noise.
CRX_RR
19
Mar 25, 2011 03:11 PM
swizz977
11
Aug 13, 2010 08:45 PM
w0ng_sta
Dec 7, 2006 09:12 AM
w0ng_sta
MeanGreenEG9
Dec 16, 2002 07:20 AM
