Suspension & Brakes Theory, alignment, spring rates....
Sprint springs
Old Aug 11, 2009 | 03:14 PM
Marc_EE9's Avatar
Default Sprint springs
I had a quick search but couldn't find much in reviews, apart from some people finding them too hard on certain shocks.
Are they any good? Their website doesn't give much away.
I'm thinking about putting them on Bilstein "Sprint" shocks, lol
Thanks
Old Aug 11, 2009 | 10:58 PM
BiG ChOr!Zo's Avatar
Default Re: Sprint springs
i have a set of Sprint lowering springs on Tokico HP sturts and they run smooth...!!!
Old Aug 12, 2009 | 12:55 AM
Marc_EE9's Avatar
nice man! nice sedan too
do you have the 3.5" or 2.5" ones?
im looking at 2.5" (60mm) for my EE9, but ive also read people find they drop less than stated.
marc
Old Aug 12, 2009 | 11:26 AM
freakin_eLRoD's Avatar
those appear to be the 2.5 inch drop. the 3.5 inch lowering springs that sprint offers come in green.
Old Aug 12, 2009 | 12:33 PM
marc
Thanks man...they are the Sprint 1000 lowering springs with a 2.50F and 2.25R drop...!!!
Old Aug 13, 2009 | 09:12 PM
whoa its len 2's Avatar
Dope, you bought them. Here are the extreme versions (3.25"/3.0"). Soft and smooth ride, not recommended for track use.
Old Aug 13, 2009 | 09:26 PM
i picked them up on sunday but haven't installed the fronts yet only the rears...!!!
Old Aug 13, 2009 | 10:59 PM
jgcivic's Avatar
I ran this set up on my last EF hatch the ride was great. it was a fun daily set up.
Old Aug 14, 2009 | 11:47 AM
babiboidb1's Avatar
got sum SPRINTS for sale run real smooth. put a set of SPRINTS on my dads accord
Old Aug 14, 2009 | 11:19 PM
sayyoooon's Avatar
which struts would you guys pair the 3" drop ones with?
Old Aug 15, 2009 | 04:48 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
You'll need something like Koni Sports to properly handle a 3" drop. Tokico HP's will not work well and the car will probably bottom out all the time.
Old Aug 15, 2009 | 06:17 PM
racebum's Avatar
i can tell by the winding those rates are not that firm. what a poorly designed piece. 3" drop and mild rates. talk about a header - oil pan killer.
Old Aug 15, 2009 | 08:56 PM
crxtuner0's Avatar
i like your stance
im considering ordering these
what tire size are you running just as an idea to what my gap would look like?
Old Aug 16, 2009 | 04:04 PM
jmaze's Avatar
nice looking drop on both cars ! i think sprint does a good job with 1/4 lower in front.
Old Aug 16, 2009 | 10:47 PM
Nope not firm at all, soft and comparable to Eibachs. You have to remember that the engineering for these were done years before the issues with headers and swaps in "slammed" cars were abundant. They were made to give a soft ride at a low stance (for cars at the time which were near stock) and have done so successfully. Low headers and swaps werent an issue until their popularity arose after the springs were designed and produced.
Im running stock everything under the hood, the suspension will bottom out/upper arms will contact the chassis way before the oil pan reaches the ground. Of course with a swap or even 4:1 header it will be a different story.
Originally Posted by crxtuner0
i like your stance
185/60/14, fronts rub the fender on turns, rears rub the top of the fenderwell on big dips... just a couple issues youll have right off the bat.
Old Aug 17, 2009 | 01:00 AM
racebum's Avatar
x2
well said
i didn't even consider this angle when i made my comment
Old Aug 18, 2009 | 07:27 PM
Community Builder
Someone explain this to me please. With a 3" drop, the front suspension has VERY little room to compress. If these springs have so-called "soft" rates, then how could the ride possibly be smooth? To have a smooth ride would mean the suspension isn't bottoming out, and with that much of a drop on "soft" rates, I would think the suspension would bottom out ALL the time, giving anything but a smooth ride.
Old Aug 18, 2009 | 09:52 PM
I agree, "smooth" and "soft" may be contradicting terms. What I meant was, in comparison to higher rated springs, the rebound with the Sprints are not as quick or stiff. They also are not so soft that it consistently bottoms out. Only when head on with larger dips would the issue of bottoming out arise. On average sized dips there is enough suspension travel to contain the impact, at least with my setup.
Both low and high rated springs have their version of discomfort when head on with disturbed pavement, even when matched with properly valved shocks. "Soft" was the description I gave the Sprints as opposed to "hard" for higher spring rates. I was simply describing the feel of a ride based on a spring's recovery speed and level of intensity between different rates.
As far as the term "smooth", its all relative to an individual's perception of comfort. Hard+smooth vs. soft+smooth... all can be contradicting terms but can also be used to loosely describe the feel of a ride.
Old Aug 18, 2009 | 10:12 PM
crxtuner0's Avatar
im running 195-50-15 so i should be fine with tire clearence
and my driving style isn't extremely aggressive
i guess ill be ordering these within the next few paychecks
anyone got a good site they ordered theirs off of?
on ebay they want like 200 but i saw other places but want to know of one thats reliable
thanks
Old Mar 30, 2010 | 07:49 AM
jmaze's Avatar
are integra and civic 2.5 sprint springs the same spring rate? i thought they were the same part number.
Old Mar 30, 2010 | 06:34 PM
B16-CRX's Avatar
I have the green springs on my crx which is a 3" drop in the front and 3.5 in the back if I recall. I have tokico illuminas and it only bottoms out in the front over really bad potholes.
Old Jan 31, 2011 | 03:11 PM
1fastvtec's Avatar
I'm lookin at their sport springs for my DA Teg'. They say 2" all the way around. Anyone have any pics of them?
CivicFTW
Suspension & Brakes
Aug 13, 2010 06:59 PM
Fook_me_honda
Dec 29, 2006 09:05 PM
onnoff7
Suspension & Brakes
May 1, 2006 05:04 PM
