Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
01 CRV rear brakes
Old Aug 11, 2009 | 02:34 PM
ShortbusEK's Avatar
Default 01 CRV rear brakes
I have an 01 CRV lx.. FWD.. it has drum brakes in the rear. I will be using it to tow a small boat soon and would like o upgrade them to disks. I did a little googling but came up with nothing really.. It would seem that all the CRV's 97-01 had rear drums. I havnt crawled under to check stuff out.. wouldnt surprise me if integra/si "hubs" and brakes would bolt right up.. Im gonna look at everything side by side with my civic.. but wont have time for this until the weekend.. anyone have any info?
Old Aug 11, 2009 | 05:00 PM
jesse95's Avatar
Default Re: 01 CRV rear brakes
interesting!
Old Aug 11, 2009 | 09:18 PM
EL Vap133's Avatar
I looked into this shortly because I hate drum brakes. It appears that the trailing arm is the same but the LCAs are definitely different, being that I have the AWD CRV I would not be able to use other brakes but you might be able to. Maybe you can use the brake components and bolt them onto your existing trailing arms?
Old Aug 12, 2009 | 01:00 PM
ShortbusEK's Avatar
this is what i am thinking... my civic is on jack stands at the shop i work at (35r turbo upgrade! 30+psi here i come! =P)... i am going to work on it this weekend so i will do some comparing.. if the brake components wont bolt on id bet teg/civ trailing arms will work.. more info this weekend!
Old Aug 12, 2009 | 01:10 PM
ALLxMOTOR EG's Avatar
Vietnamese!
Get back to us because HT wants to know also.
Old Aug 13, 2009 | 06:15 PM
Hawkze_2.3's Avatar
Yes, please post up anything you find out I'd love to convert mine and there's lots more more people that would do it too...
Old Aug 14, 2009 | 07:54 AM
EL Vap133's Avatar
Here, send this guy an email and take some pics of the rear brakes of the CRV:
mparise57@gmail.com
His name is Mike, he is known on Honda-Tech as the "Brake Expert" and that is what he is, an expert. He has pieced many different brake components to make "X" brakes work on "X" car.
Old Aug 23, 2009 | 10:16 AM
ShortbusEK's Avatar
sorry all.. got tied up last weekend and didnt get a chance to check stuff out.. as far as i can tell there is no way to bolt disks to the CRV's real trailing arms.. and just a quick glance at both civ and crv trailing arms swapping them woul not work.. the crv's are about 5-6 inches taller where the upper arm connects to. so its not gonna be easy if its even possible.. will let HT know if i figure something out
Old Aug 23, 2009 | 02:27 PM
Perfectionist's Avatar
Hope it's different on the '01, but the '02 rear disks were a chronic problem for me. They required an annual disassemble/clean/lubricate/reassemble or they would make noise or drag. Granted, this is in the saltbelt, but haven't had that persistant type of problem on my other cars.
Old Aug 24, 2009 | 08:28 AM
sikbrik's Avatar
There's a sticky about this on HondaSUV. Type R and Prelude discs are close and it looks like it a simple re-drill for the bolt pattern or maybe an adapter. Shouldn't be a huge deal, but not a 'bolt on' like the Civic drum to disc swaps.
Old Aug 24, 2009 | 02:19 PM
ShortbusEK's Avatar
did some more research today.. it seems like putting bolting the rotors on is easy... just take the drums off and put rotors on the hubs.. the trick will be fabing some sort of bracket to hold the caliper... im gonna look into it.. more info soon
EL Vap133
Honda CR-V & Element
12
Aug 11, 2014 05:34 PM
hondateg08
Honda Civic (2006 - 2015)
15
Mar 27, 2009 01:05 PM
808k20hatch
Sep 18, 2006 01:40 AM
hybridbook
Jun 12, 2003 10:18 AM
