POOR MANS TYPE R TIMING COVERS
Old Aug 11, 2009 | 12:59 PM
grant97teg's Avatar
Default POOR MANS TYPE R TIMING COVERS
IF RUN A B16 HEAD ON A GSR BOTTEM END, WHAT TIMING COVERS DO I NEED TO FIT CORRECTLY?
THANKS
Old Aug 11, 2009 | 01:02 PM
VTEC_PRODUCTION's Avatar
Default Re: POOR MANS TYPE R TIMING COVERS
are you serious?
Old Aug 11, 2009 | 01:19 PM
4 door beast's Avatar
you can use the original one theyre the same
Old Aug 11, 2009 | 03:05 PM
Circusraven's Avatar
Originally Posted by VTEC_PRODUCTION
are you serious?
I believe he is...
You can use a P72 lower timing belt cover. Assuming you're using your stock GSR/ITR oil pump. If you're using a B16 oil pump for some reason, you'll have to use a PR3 lower cover. You can use a B16 upper timing cover with the P72 or PR3 lower cover.
guedo148
Jul 8, 2009 07:22 AM
foam
Dec 26, 2005 10:23 AM
RaysBoomBoomLude
Aug 28, 2005 06:40 PM
85mm LS VTEC
Aug 4, 2004 02:18 PM
MisterB
Jan 24, 2003 06:37 PM
