what have you guys done to adapt the FITV on to an aftermarket intake mani?
Old Aug 11, 2009 | 11:15 AM
949's Avatar
949
Default what have you guys done to adapt the FITV on to an aftermarket intake mani?
i got the skunk2 intake manifold. i wanted to still use the FITV for the normal warm up in the morning.
what have you guys done to get the fitv to still work?
Old Aug 11, 2009 | 11:46 AM
gringo7718's Avatar
Default Re: what have you guys done to adapt the FITV on to an aftermarket intake mani?
Get a throttle body from an OBD1 B-series (LS or GSR - both 60mm). These have the FITV that bolts under the throttle body.
Old Aug 11, 2009 | 05:24 PM
949's Avatar
949
thanks i didnt know that.
i have the blox throttle body now.
i dont think it has that on the bottom.
does skunk2 have that?
Old Aug 12, 2009 | 07:36 AM
949's Avatar
949
will the fitv from that work with my obd0 plug? or do i need to rewire it?
Old Aug 12, 2009 | 08:14 AM
gringo7718's Avatar
The FITV does not have any wiring. It is a mechanical device that raises cold idle and once the car warms up, it closes and does not affect idle in any way.
The IACV on the other hand, attaches to the back of the manifold. It adjusts air bypassing the TB to regulate idle all the time. It has wiring and is controlled by the ECU.
dohc4life
May 8, 2011 11:42 AM
949
Feb 21, 2011 07:03 PM
Joeski99Si
May 22, 2008 06:40 PM
tgh22a
Mar 19, 2005 03:43 PM
