Suspension & Brakes Theory, alignment, spring rates....
Broke a bolt in control arm.
Old Aug 11, 2009 | 09:51 AM
YZF's Avatar
YZF
New User
Default Broke a bolt in control arm.
So I go to take out the rear struts (to put on some Eibach springs) off the car and broke the first bolt I went to take out. Now, after messing with it for a few minutes, I have this chunk of bolt stuck in the bushing and I'm not sure how to get it out. It's pretty much level (flush) on both sides, including the 3/4 or 19mm bolt that was welded to the strut because I broke that off as well in attempt to pull it through the front side.
What would you suggest?
Old Aug 11, 2009 | 06:25 PM
Egezzy's Avatar
Spongebrad Squarepants
Default Re: Broke a bolt in control arm.
buying new lcas. easier in the end.
Old Aug 12, 2009 | 06:46 PM
StolenTeg's Avatar
This is a common problem, the bushing and the bolt rust/seize into one overtime. You need to push that old bushing out and push in a new one if you wanna reuse the LCA or get different one
FrontwheelENT
26
Jul 23, 2012 01:22 PM
cletus11
Mar 6, 2011 02:17 AM
irideslammed5021
12
Mar 28, 2007 04:02 PM
sohc_student
Suspension & Brakes
Sep 4, 2006 11:05 PM
LsNer00
Jun 29, 2004 12:09 PM
