A/C Question. HELP!!!
Old Aug 11, 2009 | 09:11 AM
vche101's Avatar
Default A/C Question. HELP!!!
Guys, i have a EK Hatch with OBD1 GSR swap. I wanna put my a/c back on and i was wondering if i have to get everything from EK Civic and lower a/c mount from crv/del sol or if i could reuse my lower a/c mount and compressor from the 94 DC that came with motor and get everything else for the EK Civic. Any help would be appreciated. Thanks in advance.
Old Aug 11, 2009 | 09:54 AM
hOnda_hiEn's Avatar
Default Re: A/C Question. HELP!!!
easiest way is to get all the a/c components from the ek civic along with the sohc compressor.. and then just use the crv/delsolb16 a/c bracket.. P54 bracket..
Old Aug 11, 2009 | 12:52 PM
vche101's Avatar
Yea, I understand that. I'm just askin since I have the DC lower mount ac bracket and compressor, can I use it or is it a pain in the neck to get it to work?
Old Aug 11, 2009 | 01:26 PM
Vindicator9000's Avatar
318 Curves, 11 miles
yes, it's a pain in the neck. I asked the same questions when I got a free DC2 compressor with my gsr swap, and seriously looked at doing it that way.
If you look at a Civic compressor and a DC compressor side by side, you'll see that the hose connections are clocked opposite. So, to run civic hoses into a teg compressor, you have to twist them all crazy, and I'm not sure that it will work at all. If it does work, I'm not sure that it's good for the hoses. The bolt holes just don't even come close to lining up.
Now, if you used teg hoses from the compressor to the rest of the Civic AC system, that may be possible, but I've never tried it or seen if they'll even mate up. It may be easy, but I've never seen it done in 6 years of lurking here. I've not seen it myself because I didn't have teg hoses at the time that I was screwing with it.
Unfortunately for you, the easiest, bolt-on, tried-and-true method is to use all Civic AC parts with a B20 mount bracket.
Old Aug 11, 2009 | 03:13 PM
vche101's Avatar
thanks for all your help! I really appriciate it. The bracket I need is the b20 p54 from crv or del sol, rite? Once again Thanks for all ur help.
Old Aug 11, 2009 | 03:21 PM
civicsmoke's Avatar
not to thread jack but if you use the b16del sol bracket on a civic with civic ac which belt will you need?
Old Aug 11, 2009 | 03:26 PM
shyboi4u's Avatar
crv ac belt
Old Aug 11, 2009 | 03:31 PM
civicsmoke's Avatar
Originally Posted by shyboi4u
crv ac belt
great thanks alot
Old Aug 11, 2009 | 03:37 PM
crv ac belt
really doesn't matter. I used a d16y8 belt. B series belts work too.
Old Aug 11, 2009 | 05:41 PM
civicsmoke's Avatar
then why is it that i installed a b16 mount onto my b18b block bolted on my d series compressor and the b16 ac belt wouldnt fit? I had to remove the tentioner completly for the belt to fit, its pretty snug and im willing to bet it will snap thats why i was wondering what belt to get. thanks
Old Aug 11, 2009 | 05:47 PM
Interesting. Don't know, other than that I'm running a CRV bracket with a d16 belt, and it's not abnormally tight. Wonder if the different mount is the reason.
shortstopNE
Apr 19, 2012 08:15 AM
geebs
Sep 24, 2008 05:46 PM
SyDuck
Jul 16, 2006 12:34 AM
JDMB18CEK
Jan 20, 2003 11:43 PM
JDMFreak
Oct 14, 2002 07:28 AM
