Fuel pump, Main relay, No spark = I need help quick!
Old Aug 11, 2009 | 05:39 AM
SiR-G DC's Avatar
Default Fuel pump, Main relay, No spark = I need help quick!
Ok so i went to turn on my car yeterday after switching my cluster out for an ITR.
I try'd to turn it on and i didnt hear the Main Relay or Fuel pump turn on. I checked the main relay and it's fine, Fuel pump and it's fine. I did the Fuel Pump mod from the main relay and when i turn the key on i can hear the fuel pump prime and main relay click but car still wont turn on. I checked for spark and it's not getting any? Any ideas or thoughts? I switched dizzy's and everything, Still no spark...
Old Aug 11, 2009 | 11:55 AM
racebum's Avatar
Default Re: Fuel pump, Main relay, No spark = I need help quick!
you check the fuse cluster yet?
Old Aug 12, 2009 | 05:24 AM
SiR-G DC's Avatar
Fuse cluster? I checked the underdash fuse box with nothing blown and the engine fusebox, Nothing again.
Old Aug 12, 2009 | 05:45 AM
1993-eg1's Avatar
what about your ecu or grounds that u may have messed with i know it shod not be grounds but **** happens
Old Aug 12, 2009 | 12:01 PM
acura_crx_x71's Avatar
i am having the same problem with a 92 teg, ive changed main relay,fuel relay, checked fuses nothing is blown, fuel pump works but only when i tested to battery, not gettin any spark at all
any ideas to change or check
Old Aug 12, 2009 | 12:07 PM
racebum's Avatar
in your case the distributor, however, the op has already done this.
i'm stumped in the op's case.
normally the main relay or a distributor are 99% of the cause in these no spark situations
Old Aug 12, 2009 | 12:59 PM
SiR-G DC's Avatar
And this would be my luck
Old Aug 12, 2009 | 01:00 PM
SiR-G DC's Avatar
I checked the ECU and swapped it out, Nothing.
Old Aug 12, 2009 | 03:09 PM
i tried 3 different distributers and still no spark and put a brand new main relay from parts store still no spark, im hookin up my pump to a switch and how would i hook up the ignition to a switch (if possible)
Old Aug 12, 2009 | 05:32 PM
ok my integra fired and ran fine other than poppin from sittin for 6 months or so....all we did was re-did the connection for the fuel pump wires
Old Aug 12, 2009 | 05:34 PM
racebum's Avatar
i had a feeling it was some loose connection. it's the only thing that made sense. it's just impossible to even venture a guess over the net as to where it could be. glad to see that it's been taken care of
Old Aug 12, 2009 | 05:46 PM
SiR-G DC's Avatar
Thats not me posting lol. He took care of his issue but mine still continues.
Well i noticed my cluster is not working. It lights up with the parking lights on but the E-Brake, Seat belt, open door or any lights are coming on. Not even the check engine when i jump it to read it.. WTF.
Check main grounds and wires, Still stumped!
Old Aug 12, 2009 | 06:15 PM
racebum's Avatar
you have a grimlin
it's kind of the same story though. you have to keep checking the wiring until you find the problem. i really really feel for you. i'd rather rebuild a motor than do what you are. it's hours of time consuming head scratching
Old Aug 12, 2009 | 09:30 PM
BAYsikDC4's Avatar
did you try putting your old cluster back in?
Old Aug 12, 2009 | 11:50 PM
racebum's Avatar
wouldn't that be just crazy if his car magically started LOL............i've seen weirder **** though
btw: what year is this thing? didn't some of the later cars have that immobilizer? i have a 97 which does not but i thought some of the obd2b cars did. how do you trip that thing? any chance that you did?
Old Aug 15, 2009 | 10:15 AM
SiR-G DC's Avatar
I did put my old cluster back in, Nothing still. It's an 01' btw
And yes, I just rebuilt the motor and it was easier then doing this ****! only has 2,300 miles on it. I'm going back to storage to pick up my old ECU and see what that does..
I have a Chipped/tuned P28 with Phearable.net harness so i wouldn't need to do anything with the immobilizer.
Old Aug 15, 2009 | 05:33 PM
Oreo-TeCk's Avatar
does ur car back fire? if it doesnt u need an acu... i'm almost certain... bad ecu will not allow ur distributor to work
Old Aug 20, 2009 | 08:04 AM
SiR-G DC's Avatar
Try'd different ECU's too. Nothing.
I just ordered my new Ignition Switch from Acura so it'll be here tomorrow
If that doesn't work, I dont know what else to check.. I'm stumped!
wtfisvtec??
38
Jun 30, 2024 05:13 PM
Scarekrow
Oct 11, 2015 08:05 PM
EJ8CIVIC
Jul 7, 2015 03:47 AM
3easy21
Jun 11, 2012 07:27 PM
Lsweez
Jun 28, 2007 10:08 PM
