car not starting
Old Aug 10, 2009 | 11:35 PM
youryanyou's Avatar
Default car not starting
just swapped in a d15b and its not starting.its cranks n all.
but what i see is water leaking from the intake manifold im guessing a bad gasket.
but would this keep my car from starting?i had IM problems before but never water comming out and the car would start.
Old Aug 11, 2009 | 07:57 AM
Former User's Avatar
Default Re: car not starting
If the head gasket is leaking like a sieve, then the cylinders will fill with coolant and also lack compression. This definitely could lead to a no-start problem.
Old Aug 11, 2009 | 09:19 AM
craiger28's Avatar
Drain the water from the radiator and motor, if it starts you know you have a problem with the head gasket and/or a warped head. This has happened to me before and it would start and then when I added water in the radiator it would stop running. You could always jsu take the head off and look into the cylinders as well but ... more work.
jdmboy96
18
Sep 3, 2009 08:51 PM
masterkill455
May 21, 2009 10:18 PM
turbols99
Feb 5, 2007 07:28 PM
Gumbey75
Feb 23, 2005 04:08 PM
whagkangmakulet
Sep 23, 2002 08:32 AM
