ep3 buddy club short shifter
Old Aug 10, 2009 | 08:46 PM
supercivicstack's Avatar
Default ep3 buddy club short shifter
i have a Buddy Club short shifter an ever since i installed it about a year ago certain gears get harder an harder to punch in. like wen im gunning it from 1st to 2nd very often it wont go in, it just grinds really bad an i have to try again. an ever since i got the car (before the BC short shifter)when i throw it in to 3rd very often there's a grind sound. It sounds like a knock off super sequential bov but its my trans that's making the noise. help me out dudes i heard it's my drive line or drive wire i forgot but some kid told me that. a lil while back i tried honoring my "full Warranty" b/c it was getting really bad (still is) but they said i'd have to approve 12 hrs of labor = to $1,100 just to see what exactly is wrong (not including cost to fix) with it and they said they were going to have an expert come in an look at it to make sure it was normal wear an tear and not from me abusing my car. I am known to run the **** outta my car every now an then so i knew i was walking right into a $1100 trap... right?
Old Aug 10, 2009 | 10:00 PM
skyjumper_z's Avatar
Default Re: ep3 buddy club short shifter
Any chance your shift cables got bent when you put the BCSS in?
Old Aug 11, 2009 | 05:21 AM
josh's ep3's Avatar
Function > Form
It's prolly from you beating on your car. Also, a common thing with people that have short shifters is that they tend to shift "too fast" and because the timing is off between you pressing the clutch in and shifting gears, you most likely will go in too quickly and it creates a small grind everytime you do so. So, overtime this will get worse and worse. Another possibilty is that you might need a new throw out bearing, but it's hard to tell with out actually hearing it, GL.
Old Aug 11, 2009 | 05:38 AM
Well you hardly touch the shift cables wen u install the short shifter it takes an easy 15 mins. I swear the ep3 is the simplest car to jack a radio. Ne ways so it can be ne number of problems that are just gonna get worse rite. How can I fix this for sure? I heard I should flush my tranny an put in new fluid. Does anyone else offer a short shifter for the ep?
Old Aug 11, 2009 | 08:43 AM
josh's ep3's Avatar
Function > Form
Why not just get some real mods that will actually gain power, or performance? Or if you have your heart set on keeping your short shifter, why not get an upgraded clutch master cylinder so that your shift timing will match up again with shorter pedal travel.
Old Aug 11, 2009 | 09:39 AM
That's a great idea dude, how much do those run for? Is it a do it your self kinda job or will I need a pro?
Old Aug 12, 2009 | 10:34 AM
I think ill drop a couple bones on a clutch kit. Should help with my shifting.
Old Aug 12, 2009 | 11:07 AM
josh's ep3's Avatar
Function > Form
I've seen Omni Power MC's for $179 or so but I don't know if they make a version for the EP3 or what others will fit. Google it and see what you can find dude. Also, I was assuming you already had an upgraded clutch. If not, that would also be on the top of the list I think.
Old Aug 12, 2009 | 11:42 AM
Cool dude thanks for the help, gonna get my tanny flushed today. In about an hour I'm gonna take a look at a exedy stage 2 clutch kit. For $190, prolly offer him $175.
Old Aug 12, 2009 | 06:01 PM
no one makes an aftermarket clutch for k20a3 tranny.
thanks for the info dudes. I just got my tranny flushed a bit ago, shifting feels much smoother, thanks for all the advise.
OH the "exedy stage 2 clutch kit" i went to look at was just an oem replacement clutch, ****en punk tried selling it to me as a stage 2.
i'll wait around for sumthin else.
Old Aug 12, 2009 | 06:09 PM
EP3 FTW's Avatar
Clutchmasters makes a aftermarket clutch for the EP, i have a stage 3 in my car right now. Give THmotorsports a call and ask for Eddie. MAKE SURE YOU TELL THEM YOU HAVE A K20A3 FOR AN EP3 or they will send you a clutch for an rsx thats slightly different (personal experience)
Old Aug 13, 2009 | 05:26 AM
Wow cool man thanks for the hook up.
I actually meant to put no one makes an aftermarket master clutch cylinder for the ep3.
I know its hard to find a clutch kit too. Ill hit that up thanks!
Old Aug 13, 2009 | 06:00 AM
manuelcantarero's Avatar
if you ever want to sell that short shifter let me know i would be interested in maybe getting one for myself...how much did you pay for yours???s
Old Aug 13, 2009 | 07:49 AM
Well I'm not gonna sell mine, but I paid $160 for it about a year ago, the go for $140 on ebay brand new. Just do that. Or get that nuespeed one. I thinks its like 70 bucks but just an adapter. But that's how the old school ones are.
Old Sep 15, 2009 | 09:16 PM
jiyakku's Avatar
I had that same grind on the 2-3 shift even after I put in a new clutch assembly. Unfortunately it meant that my transmission was going out.
buymesomedunks
Oct 28, 2010 02:53 PM
an2ny888
Aug 14, 2006 09:01 AM
TeAl eG
Jun 9, 2006 04:34 PM
kaychi
Oct 6, 2005 01:24 PM
TurboHondaGuy
Aug 17, 2005 02:20 PM
