ITR vs. CTR pistons
If someone knows this please help me!
I am going to build an all motor B18b with no Ls/Vtec, right now i am thinking about putting Crower rods with CTR or USDM ITR pistons but i need to know what the compression ratio should be? i am shooting for high Compression. Which piston would be easier to install and to use for daily driving but also performance wise?
In an LS block on LS rods, JDM ITR pistons give 10.3:1 compression, CTR pistons give 11.4:1 compression, JDM B16a pistons give 11:1 compression.
Ur best bet for the money is find PR3 or P30 pistons. (JDM and USDM B16A pistons)
Thanks for info guys.
Ummm.... The CR specs look fine... but I don't think you can press ITR or CTR or any stock Honda piston onto a Crower rod.... different wrist pin design.
You'll need to use a stock Honda rod to use these pistons.
X2
GOLDBERG
Jun 2, 2003 07:26 AM
