Ecu Question (Swapping between cars)
Old Aug 10, 2009 | 06:51 PM
jord18's Avatar
Default Ecu Question (Swapping between cars)
Hi there,
Quick question, my buddy just installed a JDM GSR into his ek and long story short its running like *** while its cold and we think it could be a bad ecu. If i put my chipped p28 into his car just to try it to rule the ecu out of the equation, is there anyway my chip can get damaged?? Or since its obd1 nothing will happen?? I just want to confirm this, to my knowledge nothing will happen but I just wanted to make sure.
Thanks
Old Aug 11, 2009 | 01:32 PM
Relic1's Avatar
Default Re: Ecu Question (Swapping between cars)
IF the fueling and ignition requirements are similer, then it should be ok to start it and let it run.
But if the engines are very different it may run worse since the fuel and ignition settings will be way off.
IF everything is ok with his swap then it will not damage your ECU in anyway.
But keep in mind that a common problem with swaps is switching the EVAP purge solenoid and IAT plugs, this causes the car to run rich and poor especially when it's cold. It will also pop one of the transistors in your ECU.
91sidude
Jun 29, 2008 03:11 PM
obuhmyuh
May 18, 2008 09:42 PM
PrestonCRX
Mar 16, 2006 06:09 PM
volkracing99
Jan 17, 2002 01:06 PM
