reoccurring problem... help if you have any idea!!
Old Aug 10, 2009 | 06:17 PM
jro06's Avatar
New User
Default reoccurring problem... help if you have any idea!!
I have 2001 honda accord... 2 dr v-6
once a month or so, my check engine light will come on..
when this happens, my car when in neutral or clutch is pressed down the rpms will go really low(to about 100 rpms) and then go up to about 400.. the car begins to rattle.... usually my idle runs about 800-1000 rpms... what's weird is if i am in neutral and my rpms are running low i can pump the brakes repeatedly and the rpms will climb to 1000 or to a normal idle speed...
any idea what this could be??
i've tried raising my idle speed but that doesn't work...
Old Aug 10, 2009 | 11:24 PM
alkoholikwun's Avatar
Default Re: reoccurring problem... help if you have any idea!!
what CEL code are you throwing
xfactor4774
Apr 17, 2014 12:28 PM
Nisif
Nov 26, 2011 07:22 PM
ThaBread
34
Oct 23, 2008 02:58 PM
TylerW
Aug 7, 2005 01:31 PM
