Siezed Water Pump and Broken Timing Belt.
Old Aug 10, 2009 | 05:42 PM
Shaw14's Avatar
Default Siezed Water Pump and Broken Timing Belt.
SO i was doing 65 in the fast lane on the freeway when I broke my timing belt on a d15b so I get it to the shop notice water coming outta the water pump pulled apart and saw a small pin hole link long story short put a new belt on after i timed the motor and new water pump and started right back up no bent valves nothing this is second timing belt ive broke on this car why am i not bending valves is this not an interference motor? thank you.
Old Aug 10, 2009 | 05:57 PM
40mpg_dx00's Avatar
Default Re: Siezed Water Pump and Broken Timing Belt.
Yea, you definitely shouldn't be on a third t-belt. Are they being over-tightened or too loose? are they tearing or snapping?
Old Aug 10, 2009 | 09:02 PM
MuscleKarKiller's Avatar
New User
yes, its an interference motor but you may have gotten lucky. check to see if the belt tensioner is bad.
Old Aug 11, 2009 | 04:21 PM
Shaw14's Avatar
the first one was my fault let it get old you know then it wore away last one was just a mecahnical failure but im following right by the book to put together.
Old Aug 11, 2009 | 05:00 PM
98civdx's Avatar
Master Detailer
your just getting lucky, some one is doing something wrong when they put this in, its to loose, or too tight. that our your just getting peice of **** timing belts. or tensioner is bad, which you should just replace anywas.
Old Aug 11, 2009 | 06:30 PM
Shaw14's Avatar
OK like i said the first damn time it was a old belt this time i had a faulty water pump it sized causing the belt to snap i simply asked why im not bending valves i do all work my self thanks. And yes buying goodyear gatorback belts.
Old Aug 11, 2009 | 06:33 PM
roadsqueegy95's Avatar
ya man, keep getting a attitude, that will get ur question answered faster!!! and ur just getting lucky! you SHOULD be bending them
Old Aug 11, 2009 | 09:00 PM
98civdx's Avatar
Master Detailer
i answerd your question you dumb ***, so did the other guy!
your getting ****ing lucky get it?!?!?
it is a interference motor but sometimes they dont bend valves, consider your self lucky it didnt take out your head.
Old Aug 12, 2009 | 06:03 AM
honda.lioness's Avatar
From reading reports on the internet over the years of failed Honda timing belts, it seems like over half the time there is no valve damage. Civics have interference engines, but I figure either the valve reliefs on top of the pistons help preclude damage; or maybe the pistons can push on the valves some without damaging them; or maybe the valves land in mid-position pretty easily; or all of the above.
Old Aug 12, 2009 | 10:27 AM
Shaw14's Avatar
wow you all are so tuff alls you guys wanted to say is i was buying cheap parts or doing something wrong lol go read original post i didnt wantto be told whatg ive done wrong but thank you honda lioness only resonable answer in thank god i daily drive a honda and thank god i race racecars at race tracks with v8's.
Old Aug 13, 2009 | 12:26 PM
98civdx's Avatar
Master Detailer
your a idoit! i ****ing told you, and answerd your quesiton 2 god damn times.
yea you race v8s and they rape you
Old Aug 14, 2009 | 07:10 AM
Shaw14's Avatar
No dumb asa called ASA stock cars yes I do race them dumbshit. Come to south sound speedway evergreen any place you want im there and you can see track champion at work.
Old Aug 14, 2009 | 07:27 AM
alphalanos's Avatar
Ok relax.
Old Aug 14, 2009 | 07:53 AM
jdm_Jim's Avatar
lol why ask for help then get mad at the people who help you? then act like a d*ck and try to seem cooler than them because you are track king. Are you jeff gordon? if he got on this thread are you going to say you are better than him? no, you wouldnt.. just like you dont know who else youre talking to online.
Old Aug 14, 2009 | 10:37 AM
98civdx's Avatar
Master Detailer
track champ hahaha,
track champ and yet he doesnt know why he hasnt bent valves!!
Old Aug 14, 2009 | 10:47 AM
sde780's Avatar
You lucky, that is all
Old Aug 14, 2009 | 12:07 PM
Shaw14's Avatar
No just all you Honda people think you guys are god but your not so anyways go play with your 4 cyl and ill go play with v8s.
Old Aug 14, 2009 | 12:54 PM
sde780's Avatar
Nobody's said they're God. Grouping everyone into "Honda people" is pretty stupid too.
Old Aug 14, 2009 | 01:04 PM
CivicPride97's Avatar
wow he said go play with our little 4 cyl yet he's here surprised and dumbfounded on why he hasnt bent any valves....second of all ive seen little 4 cyl rape the s*** out of V8s...No body here think of themselves as gods and the point is we are here to help out fellow honda members but obviously your not good at taking comments or opinions...might wanna try some anger management and get back at us when you figure out why you havent bent any valves...ill go play with my little 4 cyl which im so proud of anyways!
Old Aug 16, 2009 | 06:34 PM
Shaw14's Avatar
These are actual racecars like you see on TV thank you.
Old Aug 17, 2009 | 02:45 AM
2000siturboR's Avatar
you my friend are a stroke job.
Old Aug 17, 2009 | 10:17 AM
Shaw14's Avatar
A stroke job lol show up to one of those tracks any saturday bring any car you want gauranteed your gonna get beat.
Old Aug 17, 2009 | 02:48 PM
bench racing FTL. what a doush bag.
Old Aug 17, 2009 | 04:18 PM
D3vin's Avatar
Why do I always stumble upon threads like this when searching for answers.....
Old Aug 17, 2009 | 04:23 PM
Micha's Avatar
FAILWGN
What is your question?
