Optimal Tire Pressure for Azenis?
Old Aug 25, 2002 | 07:19 AM
Nighthawk GS-R's Avatar
New User
Default Optimal Tire Pressure for Azenis?
like the topic states. i know alot more of you use them or used to use them as opposed to guys in the integra forum.
TIA
Just for regular street use BTW..........
Old Aug 25, 2002 | 07:41 AM
uNF$@#!'s Avatar
Default Re: Optimal Tire Pressure for Azenis? (Nighthawk GS-R)
you *****.
listen to me.
i said 40-42 psi will do
Old Aug 25, 2002 | 07:44 AM
Floyd's Avatar
For track or street?
Old Aug 25, 2002 | 07:55 AM
HondaRcB's Avatar
Default Re: Optimal Tire Pressure for Azenis? (Floyd)
I've been running 35F 33R on the street and 42F 45 or so R for autocrossing, which seems to be working well.
Old Aug 25, 2002 | 08:58 AM
Dr Pooface's Avatar
Default Re: Optimal Tire Pressure for Azenis? (George Knighton)
I keep mine at 33/35 street and track.
Old Aug 25, 2002 | 09:02 AM
rainmanEK's Avatar
big strong guy
Default Re: Optimal Tire Pressure for Azenis? (Ddub)
why does everyone raise pressure for track? or auto x? less air = more traction
i use 35psi street, and around 28 front/30rear for auto x! eric
Old Aug 25, 2002 | 09:08 AM
Rguy's Avatar
Voted Best Looking GDD Poster
25 Year Member
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Optimal Tire Pressure for Azenis? (rainmanEK)
Maybe fopr drag racing that is true..but having higher tire pressure usually is a good thing...of course not too high.
Old Aug 25, 2002 | 09:11 AM
hooptie157's Avatar
Default Re: Optimal Tire Pressure for Azenis? (Rguy)
I just run 37 all around
Old Aug 25, 2002 | 11:07 AM
HondaJon's Avatar
Default Re: Optimal Tire Pressure for Azenis? (hooptie157)
I was running 37f/35r for my last auto-x, but I found that I was scrubbing the edges quite a bit, so for my next auto-x I'm going to up the pressure to maybe around 42 or so.
Jon
Old Aug 25, 2002 | 02:20 PM
JDMb18civic's Avatar
Default Re: Optimal Tire Pressure for Azenis? (HondaJon)
mines about 33psi front and back
Old Aug 25, 2002 | 05:29 PM
01TypeR680's Avatar
New User
Default Re: Optimal Tire Pressure for Azenis? (JDMb18civic)
i'll be the first to refer you to the search as i've asked this exact same question before.... seems like around factory specs are good for the street, higher in the front and lower in the back but then again the amount of suspension work you've done will determine your best settings, if you have easy access to an aircompressor try keeping a long and use the various pressures you try as an excuse to drive. Although you didn't ask about auto-x i've researched this topic as i dabble in auto-x w/ my azenis and i've found that LOWER pressure in the back, 29-30, works great with no scrubing thanks to the super stiff sidewalls and allows, for itrs atleast, good rotation and a larger contact patch. Although most everyone swears that if you auto-x you must run higher psi i've yet to hear of anyone trying a lower pressure in the back on the azenis and not being happy. For those reccomending the higher psi in the back for auto-x on azenis i'd be interested to see if you'd like to try out the lower psi at your next auto-x and come back and share your opinions with us. -rob
DJYoshaBYD
Dec 23, 2009 03:47 PM
Safe Drives
16
Sep 26, 2006 02:30 PM
evil510
Feb 9, 2005 12:54 PM
redboost10
Apr 27, 2004 09:37 AM
Veritas-Aequitas
May 2, 2002 03:28 PM
