enjine transplant problems(please help)
Old Aug 10, 2009 | 12:27 PM
j3ffm0n's Avatar
Default enjine transplant problems(please help)
hello there everyone, well i dont know where to start maybe a little intro of myself, I found this forum by chance on google and joined few days ago. I'm from malaysia and recently just acquire a jdm ef8 halfcut, my ride is an ef hatchback ed6 chasis running on d15b3(the engine is dead). ok well i guess thats all for now.
so yesterday me and my mechanic started work on dismantling the b16a for cleaning and overhaul purpose, once we took out the piston from the block, we noticed that the piston wall( i'm not sure what it's actual name, it's the place where you put in the piston) is not even, the wall has 2 shape. mechanic said it's probably previous owner didnt took care of the engine oil and resulting in uneven piston wall. the upper part was probably 81.5mm now while the bottom is 81mm.
so he suggested me to trim the piston wall to make it even but the problem is, is there any aftermarket piston for b16a that are 82mm or 83mm in size? if there is please do tell me... i know i can get a b20b or b18c block, but it's illegal in here and can't pass the road transport department examination(the law here require every car that did engine transplant to go thru the examination and proven road worthy before they give their approval). h22 & k20 cost a bomb here and it's not legal to be fitted in an ef, even the b16a cost around 1700 USD ~ 2000 USD over here...
thats all for now, i dont know what other problem there will be when i continue to dismantle the b16
Old Aug 10, 2009 | 02:55 PM
sde780's Avatar
Default Re: enjine transplant problems(please help)
You need oversize pistons & rings, get the cylinder bored to the right size
Old Aug 10, 2009 | 03:28 PM
iheartteal's Avatar
honda makes oversized pistons
Old Aug 10, 2009 | 08:15 PM
j3ffm0n's Avatar
ok umm, i wonder if honda oversized pistons are available in my country... thought of getting aftermarket piston, can you guys recommend some brands?
Old Aug 10, 2009 | 08:19 PM
lunalink's Avatar
i hear eagle are pretty good..but i never messed with pistons myself.
Old Aug 10, 2009 | 08:33 PM
j3ffm0n's Avatar
i got this after searching for oversized piston...wondering if you heard about it
http://www.jepistons.com/
http://www.wiseco.com/
both are in USA
Old Aug 10, 2009 | 08:34 PM
lunalink's Avatar
have you tried ebay?
im sure you can find a good set on there
Old Aug 11, 2009 | 06:52 AM
sde780's Avatar
vitara
crashsvg
Jan 8, 2010 03:21 AM
ashb82
Apr 19, 2009 07:15 PM
ianp3k
Apr 24, 2008 07:55 AM
BLKCRX
Jul 24, 2002 03:40 AM
