door trim clips (ARGHHH!)
Old Aug 10, 2009 | 10:50 AM
InTheLBC20's Avatar
Default door trim clips (ARGHHH!)
Every time i try to get some from the junkyard they f....king break on me! Im not talking about the clips for the fender or quarter panel trim, because they are different. Is there anybody out there who has DIYed some type of clip for these things? Ive been racking my brains and i need some inspiration. And im not glueing them on, so dont even go there.
Old Aug 10, 2009 | 10:57 AM
moorevisual's Avatar
Default Re: door trim clips (ARGHHH!)
i did see somewhere where someone machined some new ones. BUT you can get the red ones from the dealer.
for one of my door trims i got the red one from the dealer for the front and used 3M double sided tape on the spots where the white ones go and its holding just fine
Old Aug 10, 2009 | 11:14 AM
jmr90si's Avatar
Remove screw from the rear of the door (shuold be a 10mm on inside of doorjam) and gently tap the trim forward with a deadblow or plastic hammer. Note you can only pull trim off the door slightly as not to kink it. Be patient and you should be able to get all the clips, you may have to take door panel off as some will fall into the door.
Old Aug 10, 2009 | 11:25 AM
im not sure if you have a HB or sedan, but in my sedan if the clips fall inside the door, they're inside a boxed in portion of the door that there is no way to get them out (unless you cut into it i suppose).
Old Aug 10, 2009 | 11:37 AM
InTheLBC20's Avatar
yes i have a hatchback and its the same way, i thought i could get behind the door panel and get them but nope.
Old Aug 10, 2009 | 12:33 PM
jmr90si's Avatar
You're at the yard. Take the door off its hinges and tilt it they will fall out the back of that channel. sorry forgot about that!!!
Old Aug 10, 2009 | 02:54 PM
sde780's Avatar
Yeah, I broke EVERY SINGLE EF molding clip at the U pull it. You take off the 10mm and push molding forward, then spin the clips 90* to get out. Red one would not come out for me so I just yanked it out
Old Aug 10, 2009 | 03:26 PM
mitsubishiv5's Avatar
your not using the search engine right if you cant find the answer. ive made alot of diy.
Old Aug 10, 2009 | 04:06 PM
pandarex's Avatar
or you can buy em from honda. seems worth it to me
http://www.hondaautomotiveparts.com/...SIDE+PROTECTOR
Old Aug 11, 2009 | 09:04 PM
InTheLBC20's Avatar
Ive read your whole build thread and i didnt see any diy on door trim clips
Old Aug 11, 2009 | 09:23 PM
sde780's Avatar
just search for threads he created
Old Aug 14, 2009 | 09:22 AM
InTheLBC20's Avatar
im just gonna buy them from the dealship, they're only $2.43 a peice.
Old Aug 14, 2009 | 09:30 AM
ALLxMOTOR EG's Avatar
Vietnamese!
This is exactly how I did it too.
alex1321
12
Jan 25, 2013 08:59 PM
93CamaroLT1
May 27, 2008 04:57 AM
91hondacrx
Aug 19, 2004 06:53 AM
inty2511
Mar 25, 2004 05:27 PM
