1992 HONDA PRELUDE VTEC SWAP
I HAVE A 92 LUDE AND I AM LOOKING FOR INFO TO CHANGE IT OVER TO A H22A VTEC IT HAS A 2.3 IN IT NOW AND I AM WANTING TO GET SOME STEP BY STEP INFO ON WHAT ALL I WILL NEED TO MODIFY TO GET THIS 2.2 VTEC TO WORK.. I HAVE DONE SOME RESEARCH BUT EVERYTHING HAS BEEN DIFFERENT FROM ONE PLACE TO THE OTHER.. IF YOU HAVE ANY TIPS THAT CAN HELP.. AS FAR AS IS MOUNTING DIFFERENT..CAN I USE THE SAME 2.3 MANUEL TRANSMISSION...PCM DIFFERENCE-VTEC SOLENOID WIRING.. ANYTHING THAT CAN HELP WILL BE MUCH APPRECIATED..
THANKS
THANKS
welll 1st good luck man cuz im trying to do the same thing to my 92 lude i want to put just the h22 hean on my block but people keep telling me no or that it would not work why idk
but i was thinking if i get the h22 head the ecu plus wiring harness i think it will work
I'm about to get my JDM H22 dropped in my lude, direct swap, not many things to be modified exept maybe for a couple of connectors and you have to wire it for vtec which is very simple. You can use the same tranny but you need the H22 ecu, now if you want to make an H23vtec that's another story.
wickedxboi
Apr 15, 2003 08:28 AM
