Timing marks on CRV
I was wondering if anyone knows which of the timing marks on the cam gears to use when doing a head gasket on the K24 in the CRV.
Any help would be appreciated.
Thanks
Thanks
Probably found it by now, but here it is anyways.
2002 CR-V - Cam Chain Installation
NOTE: Keep the cam chain away from magnetic fields.
- Set the crankshaft to top dead center (TDC). Align the TDC mark (A) on the crankshaft sprocket with the pointer (B) on the cylinder block.
- Set the camshafts to TDC. The punch mark (A) on the variable valve timing control (VTC) actuator and the punch mark (B) on the exhaust camshaft sprocket should be at the top. Align the TDC marks (C) on the VTC actuator and exhaust camshaft sprocket.
- Install the cam chain on the crankshaft sprocket with the colored piece (A) aligned with the punch mark (B) on the crankshaft sprocket.
- Install the cam chain on the VTC actuator and the exhaust camshaft sprocket with the punch marks (A) aligned with the center of the two colored pieces (B).
-singlecamkillr
Apr 20, 2005 11:20 AM
