clutch replacement
Old Aug 10, 2009 | 09:41 AM
kornkid21792's Avatar
Default clutch replacement
anybody know if the ebay clutchs are any good?and whats the diff between stage 1 and 2 just how much power they can handle?
Old Aug 10, 2009 | 02:04 PM
prion's Avatar
Default Re: clutch replacement
There are other threads that cover this topic, but from what I remember:
Gripforce F1 Racing Clutches and Flywheels = OK. I have a set and several others have also had good experience with them.
XTD / XTR = poor reviews.
Exedy = Generally positive reviews. I would probably go with them for an OE replacement.
Fidanza = Good reviews for their flywheels. Aluminum is lighter, and they have a replaceable friction surface.
Those are the bulk of the ebay clutches. You can get the pricier clutches from clutchmasters and others, but I have no real experience with them.
The Stage 1 / 2 /3 business are just labels placed on different clutch material and clamping force. There is little reason to go with a stage 2+ if you are running near stock torque mostly on the street. Higher clamping force will wear out your thrust bearings faster. Higher stage clutch material tends to wear out faster and wear into flywheels faster.
There is a lot of reading material on clutch technology. Maybe someone can chime in with a good link to more info.
Old Aug 10, 2009 | 02:37 PM
Kronn 98SH's Avatar
With the clutch being such a PITA to replace, especially for SH owners, I don't recommend going cheap cheap. Exedy OEM or Exedy Stage 1 gets my vote for stock or near-stock Hondas. I also vote for the ACT 12lb flywheel.
Stage 1/2/3 are vague. Only ACT (that I've seen) actually breaks it down with hp/torque ranges for each. The other companies just slap it on there because of ricers.
"I've got a stage 3 clutch in my stock civic. I'm ready for some street racing now."
Old Aug 10, 2009 | 03:20 PM
TheCivicMafia's Avatar
If your every going to mod your lude, i'd invest in a stage 2 clutch nothing higher. But thats IF your going to mod it.
Old Aug 13, 2009 | 09:25 PM
NiteHawkLude01's Avatar
New User
Ive got a F1 racing stage 2 clutch with the Fidanza 8lb flywheel in my 01 base and love it. But its also has a few things done to it.
Old Aug 15, 2009 | 06:18 AM
street_ride14's Avatar
??? -- Why. Explain to me why I should not get anything higher than 'stage 2' if my power is 300+hp ? ..
Old Aug 15, 2009 | 06:49 PM
JDMlude3189's Avatar
cuz if you dont have stupidcharge or turbo there's no point for something higher then 3 lower then 3 is more for like all motor and stuff like that
Old Aug 16, 2009 | 03:02 AM
^ No, wrong.
and stuff like that
ok stuff like that, great.
Finnish_Racer
13
Feb 10, 2010 06:19 PM
the.hamburglar
Aug 8, 2008 09:42 PM
spotscivic
29
May 15, 2007 07:18 PM
B16'D DA9
Apr 19, 2007 05:18 PM
davidluko
Sep 4, 2006 10:42 PM
