a/c and knocking sound
Old Aug 10, 2009 | 08:29 AM
tmoney123's Avatar
Default a/c and knocking sound
i have two problems my a/c is not blowing cold air what could be my problem i have 2000 honda civic just swapped a jdm GSR in there and the a/c on that motor seems to not be workin anyone have any tis i could try to fix it?
my other problem is i have lowered my car with coilover about 3 years ago and now i am starting to hear this knocking sound on my right front wheel when i make turns or shift gears sometimes. any suggestions? thank you
Old Aug 12, 2009 | 09:13 AM
Vampire2o9's Avatar
Default Re: a/c and knocking sound
First of all try to be very specific as problems will vary from person to person. Make sure you type clear and understandable.
The A/C problem can be: leak from one of the A/C lines or low freon. It can also be that maybe your temperature actuator valve is stuck on hot. You might need to check if the valve switches over when you move the slider to cold or hot. Or perhaps even the A/C button is off.
As for the knocking:
If you hit bumps and you can really feel them, its probably your shocks going out.
If you hear clicking when you turn only in a certain direction, it's probably a shift boot/axle problem.
If theres a little bit of sound but jerking when the car starts going or abruptly changing pace, It might be a bad mount.
hope that helps...
plai
Acura TSX
12
Oct 10, 2011 09:13 PM
speed2985
Oct 24, 2006 04:32 PM
todnshay
Aug 8, 2004 05:53 PM
SPOOLINVTEC
Dec 18, 2003 01:19 PM
brads94accord
Jun 3, 2003 07:33 PM
