JDM cluster with yellow needles on a USDM... did search
Old Aug 25, 2002 | 05:24 AM
citanest's Avatar
New User
Default JDM cluster with yellow needles on a USDM... did search
Is it possible to swap just the needles? anyone did it? did search, but found nothing.
Old Aug 25, 2002 | 06:04 AM
uNF$@#!'s Avatar
Default Re: JDM cluster with yellow needles on a USDM... did search (citanest)
you can swap the needles.
you just need to do some careful recalibration.
(either by machine, or by writing down RPM <==> speed)
Old Aug 25, 2002 | 06:33 AM
Rguy's Avatar
Voted Best Looking GDD Poster
25 Year Member
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: JDM cluster with yellow needles on a USDM... did search (Soup ****)
You cant just swap needle? Why recalibrate?
Old Aug 25, 2002 | 07:31 AM
BlazinITR's Avatar
New User
IM Yoshi!
He did it to his cluster!
Old Aug 25, 2002 | 07:40 AM
uNF$@#!'s Avatar
Default Re: JDM cluster with yellow needles on a USDM... did search (Blazin ITR)
i did it to a cluster too.
you will need to recalibrate since the needles are coil loaded. open up your guage cluster and you will see what im talking about.
Old Aug 25, 2002 | 09:57 PM
Type R 2c's Avatar
I swapped the needles too.
Old Aug 25, 2002 | 10:00 PM
B2FiNiTY's Avatar
Default Re: JDM cluster with yellow needles on a USDM... did search (ISS Elite-R)
I opted not to swap them. I just solved it the easy way...
It can be done but you gotta be VERY carefull not to break them.
Old Aug 25, 2002 | 10:22 PM
skafia's Avatar
25 Year Member
Default Re: JDM cluster with yellow needles on a USDM... did search (B2FiNiTY)
oooh sounds too risky for me.
Old Aug 25, 2002 | 10:42 PM
GZR4DR's Avatar
Default Re: JDM cluster with yellow needles on a USDM... did search (skafia)
Just put the ITR cluster in your car. Why risk messing up 2 clusters. Thats my opinion anyways. I have one in mine, and it looks nice.
Old Aug 26, 2002 | 07:34 PM
CalvitoSol's Avatar
Default Re: JDM cluster with yellow needles on a USDM... did search (GZR4DR)
i recently pulled out my needles and now....ALL MY READINGS ARE MESSED UP!! how do i recalibrate?
Old Aug 26, 2002 | 07:36 PM
uNF$@#!'s Avatar
Default Re: JDM cluster with yellow needles on a USDM... did search (theory48)
use a vafc for engine rpm
for speed, in 5th gear 2200 rpm indicated on tach is 40 mph.
do it right and indicated via v-afc 70 mph is 3871 rpm.
the spedo is never accurate, not even from factory. neither is the tach.
but to put it all back to factory settings this is what you should do.
otherwise you can send it off to a shop with a calibration unit.
[Modified by Soup ****, 11:37 PM 8/26/2002]
Old Aug 26, 2002 | 08:47 PM
CalvitoSol's Avatar
i figured i can just put the needles back on while, the engine is running. isn't the rpm supposed to be between 750-900 durgin idle? and the speed just resting at zero? i also had to get a full tank to set the fuel needle. is this method ok?
also, i have a b16a delsol. from my knowledge, the tranny gearing is shorter so, wouldn't the rpm be higher at 70 mph? thanx
[Modified by theory48, 5:48 AM 8/27/2002]
Weak!EG
May 7, 2007 09:07 PM
88rexboy
Mar 31, 2004 08:42 AM
BlueIntegraBoy
Mar 17, 2004 09:50 PM
BlueIntegraBoy
Feb 17, 2004 09:56 PM
