H22A timing belt procedure
Old Aug 10, 2009 | 04:12 AM
JDM_Certified's Avatar
Default H22A timing belt procedure
i saw this is preludezone.com, is it necessary to do this when u allready top dead the whole motor?
8. Make sure the crankshaft is positioned with the No. 1 piston at TDC.
9. Align the groove on the front balancer shaft pulley with the pointer on the oil pump housing as shown.
10.Align the rear balancer shaft pulley by using a 6x100mm bolt as a alignment tool. Insert the bolt into the maintenacne hold about 3/4 the length of the bolt.
11. Loosen the adjusting nut and verify that the timing balancer belt adjuster moves freely
12. Install the timing balancer belt. Remove the 6x100mm bolt from the rear balancer shaft.
13. Turn the crankshaft pulley about one turn, then tighten the adjusting nut to the specified tq.
Both belt adjusters are spring loaded to properly tension the eblts. Do not add any extrea pressure to the pulleys or tensioners while adjusting.
Old Aug 10, 2009 | 04:48 AM
vinuneuro's Avatar
Default Re: H22A timing belt procedure
Everything must be at TDC, when you intall both the belts. Follow that procedure to put the rear balancer shaft at TDC. Align the hole with the mark on the housing to put the front balancer shaft at TDC.
Old Aug 10, 2009 | 07:57 AM
i thought that once u tdc the motor befor removing the 2 belts, everything elese will be tdc.
Old Aug 10, 2009 | 08:02 AM
vinuneuro's Avatar
The balance shafts won't stay at tdc once you remove the belts. Neither will the cams for that matter.
Old Aug 26, 2009 | 10:51 AM
crazychickenhead's Avatar
My intake cam moved several degrees as soon as I popped my timing belt off. But that was probably because one of the cam lobes had just passed the point it was fully open and was on its way to closing again. There's room to play with anyway, and you can always move each sprocket by hand to match everything back up at tdc when you're ready to put a new belt on.
Old Aug 26, 2009 | 07:06 PM
autoluder's Avatar
I am right at this part as we speak, but i try to move that intake cam and get it close and put the timing belt on, but every time i put the belt on the intake cam moves, idk, this might be a 2 person job.
Old Oct 7, 2009 | 11:12 AM
JDM99GSR's Avatar
one thing i am confuse about is , when u put the 6x100 bolt into the service hold it goes in and everything but it can go in on 4 diferent positions so which one is the correct one
Old Oct 7, 2009 | 02:46 PM
flyrod's Avatar
One position:
Old Oct 7, 2009 | 04:25 PM
autoluder's Avatar
There is a dot on the sprocket, and alignment marks at the top the the dot should be between them, or 12 o clock per say.
JDM_Certified
Aug 10, 2009 08:21 AM
hon
Sep 21, 2004 03:54 AM
Shady Hills
Jul 24, 2004 09:40 PM
fullracegsr
Apr 27, 2003 05:00 PM
Mover
Jul 30, 2002 09:35 AM
