temp guage broken
Could be from bad grounds, that would cause the described problem. Do you have all the grounds hooked up on the motor as well as the ones on the thermostat housing?
Check to see what kind of voltage/resistance is coming from the temp sending unit. It is located on the head under the distributor and has only one wire. (yellow)
Also remove the guage cluster and check what voltage is present at the proper pin location.
let us know what you find
RICE POLICE SIP
Dec 1, 2005 11:09 PM
