starting issues
Old Aug 9, 2009 | 07:34 PM
prime-R's Avatar
Default starting issues
Im having starting issues,I have 95 civic ex coupe woth a 97 integra type r motor,I turn the key and it clicks but no start,I don't know what's going it just started,any help would be apprecieated,I can't do nothing now its late but I would like to start taking suggestions
Old Aug 9, 2009 | 07:44 PM
Former User's Avatar
Default Re: starting issues
Low battery or bad starter motor are my first thoughts.
Old Aug 9, 2009 | 07:48 PM
prime-R's Avatar
Battery is new and just fine,starter tested good,so it can't be that,
Old Aug 9, 2009 | 07:49 PM
:::SIRll_EJ1:::'s Avatar
I agree ^ I would start by charging the battery and checking your "ground" wires.
Old Aug 9, 2009 | 07:52 PM
The starter doesn't crank the engine when you turn the key to ON(III), right? You hear the starter solenoid click when you turn the key to ON(III), right?
Does the starter motor get battery voltage on the large black wire from the battery?
Old Aug 9, 2009 | 07:57 PM
prime-R's Avatar
Yes and yes the starter has the big white wir that connects to it but not straight from the battery.
Old Aug 9, 2009 | 08:05 PM
Check for battery voltage on that big wire attached to the starter. The other wire to the solenoid should get battery voltage only when the clutch pedal is pushed down and the key is turned to ON(III).
Old Aug 9, 2009 | 08:13 PM
prime-R's Avatar
Yeah the guy that had the car b4 disabled that,the would start with out clutching it,
jgett002
Aug 3, 2016 02:00 PM
J1MMY420
May 16, 2014 08:46 PM
BrothaSit
Aug 14, 2006 01:21 PM
See Are X
Mar 6, 2003 10:08 PM
