90 Accord LX
Old Aug 9, 2009 | 06:26 PM
j!nx's Avatar
Default 90 Accord LX
ive been having oil pressure problems so i replaced the oil pump while i was in there i replaced the water pump and all the belts put it all back together TDC now the car wont start reset the ECU still no start. checked for codes none. checked fuses. when i put the key into the ignition the check engine light dosnt come on for 2 secs like its supposed to. there is no spark goin to the spark plugs and its a new distributor check all the connecters resseated them cheked the power goin in and out there is no power goin to the spark plugs. Any ideas? Much appreciated.
its also a 5 speed 2 door not sure if it makes that much of a difference
Old Aug 9, 2009 | 06:30 PM
GhostAccord's Avatar
Default Re: 90 Accord LX
Go back over everything that you took apart and make sure it's back together properly. Check and see that you didn't miss connecting a ground wire or maybe disconnected one by mistake. Check all of your ground & power connections to your battery as well.
Old Aug 9, 2009 | 06:39 PM
j!nx's Avatar
ive done it like 3 times since i put it together =( the car has been sitting for about 2 weeks now
Old Aug 9, 2009 | 06:49 PM
nus_dogg's Avatar
I know you might've check this but on the CDs, there's a ground wire that is bolted onto the IM. If you don't hook that back on, there will be no sparks.
Old Aug 9, 2009 | 07:33 PM
j!nx's Avatar
what do you mean by CD and IM
Old Aug 9, 2009 | 08:01 PM
nus_dogg's Avatar
Like as CD5, CD6, & CD7 Accords. ie EGs, EKs, etc. IM=Intake Manifold.
Old Aug 10, 2009 | 02:09 AM
The OP has a 1990 Accord so that would make it a CB7 Same problem with ground wires though.
j!nx - Sounds like your not getting power to your main relay and or ECU. It could be a bad relay or a ground issue. Do you have a Helms/Haines/Chiltons manual for your car?
Old Aug 10, 2009 | 03:13 AM
j!nx's Avatar
yea i have haines and chiltons and the honda shop manual
Old Aug 10, 2009 | 08:33 PM
j!nx's Avatar
well i switched out the ecu with another workin one and still nothing and im not sure how to check the relays. the main ecu relay is brand new i had the not starting issue with that.
Boostedyota
Jun 14, 2009 05:18 PM
leper messiah
Aug 30, 2008 12:27 AM
ITRICED
Mar 5, 2008 12:15 PM
simpleturbocivic
11
Apr 18, 2007 10:54 PM
YodajdmEK4
Dec 27, 2006 02:05 PM
