94 sedan .. troubles
Hey guys just picked up a 4dr today ... looked good drove decent then later on in the after noon it started acting weird.. like it was missing or not getting fuel and it was sputtering.. its a d15 non vtec I have no idea whats going on if anyone could help me trouble shoot so I can get it fixed that would be great.
Summary
Only sometimes under load it sounds like its missing or leaning out ..
I can still push the clutch in a rev it to 7k so its only happening under load
it does it in all gears but intermittently I drove almost all day with out a problem them randomly it started happening.
thanks in advance to any help anyone can give ..
Summary
it was throwing 3 codes I fixed one reset them now its not throwing any plugs and wires are new the dizzy might be bad i'll know more when I get home from work.
used 3 different idle air control valves ... they all did the same thing unless they are unhooked then the car idles fine... not sure where to go from there..
tested the fuel and have narrowed the loss in power and weird behavior down to an igniton problem im going to get another dizzy and see what that does and go from there unless someone has any other suggestions.
Sounds like it could be a bad O2 sensor. Does it misfire at WOT? If it does, then scratch my idea.
Sadly, it sounds like a bad EGR ...too bad there isn't one
If you can get your hands on another distributor, give it a shot. You have to have an OBDI unit, but I'm not sure about VTEC or Non VTEC. The mounting holes may be different.
What three codes did you have?
-Alex
-Alex
Let us know.
Caper79
14
Aug 27, 2009 11:22 AM
Nifty
25
Feb 4, 2004 04:01 AM
