D15B Harness...Doing swap now and need help!
Hey guys I'm in the middle of a swap and need help. I noticed that the wiring harness on the motor (D15B) is the opposite of where it needs to attach in the motor. I'm guessing b/c of the right had drive on the japanese del sol and the ecu is on the other side as well. I started to cut away at the wiring plastic cover to try and reverse its direction but it is very time consuming. Are there extenders that can plug in and then to the car harness? Any help would be great...thanks!
A few friends said to swap the USDM harness on....how do I wire vtec? I have the P08 ECU and the harness from the firwall to the ECU is wired for vtec but how do I wire it from the engine harness?
How would I use the JDM harness and USDM harness to run vtec? anyone know a DIY thread? Tried searching and coming up with nothing
ColinSiR
May 11, 2008 12:19 PM
