Classic Hondas All Pre-1988 Hondas.
1987 Honda CRX
Old Aug 9, 2009 | 12:26 PM
DaveBryan's Avatar
Default 1987 Honda CRX
Hey guys just bought a 1987 Honda CRX for 1300 dollars today and had a question about a problem it has. It runs find but for some reason it makes a squealing sound when you first turn it on until you let it run and give it some gas the sound is in the alternator area not sure exactly what it is didn't want to mess with it unless I knew what it was. There is also a shaking sound when you turn the key to power it and it stays on not sure what it is its coming from the engine also.
Old Aug 9, 2009 | 06:00 PM
DaveBryan's Avatar
Default Re: 1987 Honda CRX
No ideas?
Old Aug 9, 2009 | 07:25 PM
83 CVCC's Avatar
Now I'm no expert, but the squealing sound you hear is probally the alternator belt. You can usually fix this problem by replacing the belt. Im not so sure about the shaking sound though.
The car looks good btw.
Old Aug 9, 2009 | 09:40 PM
2ndGenGuy's Avatar
Nice CRX! Well worth $1300. Does the vibration noise always stick around while the car is running? Was the car modified by the previous owner? Maybe he put polyurethane in the engine mounts or something... you should actually describe the "shaking sound" in more detail...
Old Aug 10, 2009 | 06:27 AM
falkenfighter's Avatar
if the shaking sound is more like a hum or motor running then your hearing the fuel pump, they are very loud in these cars cause they arent in the tank
at least they arent on civics but i think CRXs are the same
Old Aug 10, 2009 | 08:16 AM
DaveBryan's Avatar
Its like a buzz sound and im not sure if it still makes the sound while its running I have to check because I cant hear it over the engine. But yea its a beautiful car Im new to cars so yea Im very happy with it. Also Its very hard to find first generation parts whether it be performance or stock do any of you guys have some websites I can use to find some?
Old Aug 10, 2009 | 08:18 AM
DaveBryan's Avatar
Oh and the original owner did do some work on it but its a one owner car in great condition.
Old Aug 10, 2009 | 08:21 AM
1grex's Avatar
dAng, that body is in great shape, yeh
Old Aug 10, 2009 | 08:23 AM
DaveBryan's Avatar
Yea, the car is also a DX which seems to be even harder to find parts for it.
Old Aug 10, 2009 | 11:05 AM
most parts from civics and integras will work between cars, like brakes and t-bars and alot of motor parts too
Old Aug 10, 2009 | 03:33 PM
BiGZ's Avatar
Sexy 1st gen,keep us posted! (great find btw)
Old Aug 10, 2009 | 04:55 PM
DaveBryan's Avatar
Thanks only thing Im worried about is I cant find anything for a 87 DX and its automatic.
Old Aug 10, 2009 | 05:45 PM
well the auto part... sucks but it explains the condition, little old lady owned
everything for an si will work besides the intake because they are PGM-FI
the motor is the same otherwise, suspensions same but i believe si is a bit stiffer, trannys the same but si has different ratios but its not a 5spd so...
but if you need to replace the auto then you need to find a sedan because alot more sedans came with an auto then hatches or CRXs
Old Aug 13, 2009 | 04:05 PM
DaveBryan's Avatar
Anyone have any ideas for beginner swaps for my car?
Old Aug 14, 2009 | 10:14 AM
1grex's Avatar
1st gen Integra '86-'87 "Brown Top" motors, relatively easy swap but not much gain, only 22 horse
Old Aug 16, 2009 | 08:04 PM
DaveBryan's Avatar
What's the name of the Brown Top motor is it the B18? And yea is it FI or Carbed.
Old Aug 17, 2009 | 12:14 PM
1grex's Avatar
D16A1 (DOHC) it is FI
Old Aug 17, 2009 | 12:20 PM
92teginsc's Avatar
do a manual swap when you decide to swap the motor.
Old Aug 18, 2009 | 01:53 PM
DaveBryan's Avatar
Yea I also want to do a manny swap once I swap in the future what is needed to swap a Carb to FI
Old Aug 18, 2009 | 05:49 PM
DaveBryan's Avatar
http://www.hmotorsonline.com/shop/sc...age&item=30023
Would this fit?
Old Aug 23, 2009 | 08:33 PM
DaveBryan's Avatar
My buddy has a friend with a DOHC ZC motor for 300 with tranny anyone have information on that swap?
Old Aug 24, 2009 | 01:26 AM
E-AT_me's Avatar
as long as it's an 84-87 it will bolt in pretty much. wiring is a different matter.
popthatclutch13
Dec 28, 2018 06:27 PM
looopson
May 26, 2011 10:26 PM
CuteAccord
Oct 27, 2008 01:45 PM
manyakiexpi
10
Feb 10, 2006 11:24 PM
JaredMonkey
Nov 12, 2005 02:09 PM
