01 gsr swap into 94 ls
Old Aug 9, 2009 | 08:34 AM
DFW's Avatar
DFW
Default 01 gsr swap into 94 ls
Trying to help a buddy out, what's the best route to take into this...it's complete 01 gsr swap minus ecu, going into a 94 5spd ls shell (still have engine harness). Main thing is just getting the wiring sorted, any help is appreciated.
Old Aug 9, 2009 | 09:25 AM
DC206R's Avatar
Default Re: 01 gsr swap into 94 ls
jumper a jumper harness. you're gona have to wiring for vtec. and the injectors as well.. i think.
Old Aug 9, 2009 | 09:28 AM
DFW's Avatar
DFW
Yah I know about the jumper harness, just need to know if its easy to convert the car to obd2 or the motor to obd1, then what sensors and what not need to be switched.
Old Aug 9, 2009 | 06:10 PM
DFW's Avatar
DFW
Wow...no body. Is there a better forum to post this on?
From what I've done in the past on my old 00 Civic with a obd1 gsr, I just swapped the GSR injector clips, alternator plug, dizzy plugs onto a Si harness and wire vtec. Is this anything what I'm dealing with now?
Old Aug 9, 2009 | 08:56 PM
aaronISthrowed's Avatar
No one knows....
Old Aug 9, 2009 | 11:08 PM
DC206R's Avatar
its not hard, only things that you need to do is injectors, dizzy, and alternator. think tahts it.
Old Aug 9, 2009 | 11:21 PM
Ruben19's Avatar
no need of the crank position sensor.
Old Aug 10, 2009 | 01:02 AM
DFW's Avatar
DFW
Just needed confirmation is all...
Old Aug 10, 2009 | 06:23 AM
Is that just the plugs or the whole dizzy, alt and injectors?
Old Aug 10, 2009 | 12:15 PM
PaulMc's Avatar
Painfully Stupid
He's right.
Old Aug 10, 2009 | 07:02 PM
DC206R's Avatar
i'm pretty srue its jsut the plugs on all the ones i said above. I have a OBD2 block in my OBD1 car, but i jsut swapped the OBD1 parts from my motor to avoid the hassle of wiring.
DA STRIKER
Mar 2, 2011 08:48 PM
jdm_eg6kid
May 20, 2009 04:46 PM
jlfrnce
Apr 7, 2007 05:59 AM
not so civic
Apr 3, 2002 10:51 AM
Phoenix GSR
Mar 11, 2002 03:45 AM
