JDM B16 engine and tranny ohio
Well I need to either get rid of the whole CRX or at least the engine for now. I bough the engine around 4 years ago from hmotorsonline.com for $2400. it supposedly has 35k mi on it. i have since put 15k or so on it. it is not my daily driver and i only drive it in the summer. It does not leak, smoke or burn any oil. Tranny does not grind. two years ago i replace the water pump, t-belt and belt tensioner with honda parts. the swap will include everything needed to drop it in a crx or ef hatch. i have had the injector profesionally cleaned. I also had the oil sent out and analysize and everything came back showing the engine is strong and no signs of wear.
complete engine (dizzy, alt, int. manifold, etc)
cable tranny
hasport mounts
hasport shift linkage
hasport wiring harness
ECU
axles
comptech 4-2-1 powder coated header
$2000
if this doesn't sell, i'll probably put the whole car up for sale in the spring. I'll probably sell it for $4200. No pics available right now.
engine and tranny (along with dist, alt, stock header, etc.) $1300
cable tranny
hasport mounts
ECU
axles
$2000
k0sov
Jul 12, 2004 10:50 PM
