Chipped P72 going back to stock jumper for Smog
Old Aug 8, 2009 | 12:49 PM
jetspeedz's Avatar
Default Chipped P72 going back to stock jumper for Smog
Guys im getting my P72 OBD1 chipped to tune on Crome, i have asked but i want to confirm. To go back to oem stock settings its just a matter of flipping a switch on the J0 or J1 jumper correct. I can leave the P28 chip in the ziff socket and put the stock injectors back in and call it a day....
thanks
Old Aug 9, 2009 | 11:51 AM
jetspeedz's Avatar
Default Re: Chipped P72 going back to stock jumper for Smog
bump
Old Aug 9, 2009 | 05:28 PM
98vtec's Avatar
moderator emeritus
cut the jumper from j1 and you go back to stock ecu
Old Aug 9, 2009 | 10:28 PM
jdm602's Avatar
x2
Old Aug 10, 2009 | 06:11 AM
92TypeR's Avatar
FSAE
I would think with Closed Loop enabled (assuming you still have a primary oxygen sensor), you should be able to pass emissions without a problem.
This is assuming you are still running through a catalyst, with a functioning primary oxygen sensor. If you do not have either of these, removing the jumper from J1 will not help you situation, unfortunately...
Old Aug 10, 2009 | 10:34 AM
jetspeedz's Avatar
thanks guys, no i plan on going back to stock b/c im going to be running 1000cc injectors so im keeping stock injectors and cat for smog reasons.
phrenzykEG6
Apr 19, 2010 06:35 AM
jetspeedz
Jul 20, 2009 12:21 PM
NoVALude
May 25, 2006 04:42 PM
boostedcivicsir
Aug 9, 2005 07:23 AM
