How do i know if the TIMING BELT broke???????
....The motor cranks and all but it won't start running....??? So could this be my timing belt??? or could it be something else???
pls. help me peoples
thanks
thanks
look on the right side of the engine, you might still have the plastic cover over the timing belt. just to look and see if you see it on the floor. Check if some1 can give you a jump
[Modified by nijia555, 3:20 AM 8/25/2002]
the engine would still crank if you broke the timming belt. Just pull the valve cover off and look to see if the belts there on the driver side....Mike
Perhaps a little easier: Open up the oil filler cap and see if you have some rocker movement...or you could take off the distributor cap and see if the rotor is moving.
[Modified by EE_Chris, 2:46 PM 8/25/2002]
Freemananana
Oct 24, 2015 10:22 AM
pinoyboy204
Mar 2, 2010 06:21 AM
Tippyman
Feb 18, 2006 09:04 AM
