Best transmission option for f20b
Old Aug 8, 2009 | 12:00 AM
Tight R's Avatar
Default Best transmission option for f20b
As some of you might have seen i recently installed a f20b vtec into my 97 accord. It was just a motor swap using my stock manual tranny. However the motor performs nothing better then the stock POS f22 i had in there. It definately needs a tranny and here I am wondering what is the best one to use???
i know there are several options but what would you guys suggest?
is the lsd option worth it on some of the trannys?
i was quoted 1800 dollars for the stock tranny with lsd from a f20b and personally i cant justify paying more for a tranny then the motor.
is there a cheaper and better or close to type alternative? maybe a lude??
Old Aug 8, 2009 | 09:55 AM
nus_dogg's Avatar
Default Re: Best transmission option for f20b
Try looking for a JDM M2A4 H22 tranny; gears are shorter than F22s. I'm currently running the F tranny as well and well be getting the M2A4 from my buddy since he bought himself the M2B4(LSD). The best one and is made for the F20B DOHC VTEC are the P2T4 trans but it'll cost you a arm and a leg.
Yeah, $1800.00 can get me another H22 complete swap.
Old Aug 8, 2009 | 07:41 PM
Tight R's Avatar
are there any differences in years for the m2a4??? or is it just lsd and non lsd versions??
Old Aug 8, 2009 | 08:08 PM
slammed4thgen's Avatar
incorrect, its the t2t4.
the p2t4 came in the sir- cd6.
Old Aug 8, 2009 | 09:07 PM
Proeliator38's Avatar
just try to find a regular H22 tranny unless you want to spend an arm, leg, and left nut for a EURO R/ Accord Sir-t one
PS: avoid the H22A JDM lsd ones if you plan on making any type of power and the fact that there parts are not swappable with a regular h22 trannie. Also mfactory sells a cheap lsd anyways that is way better then the oem one
Old Aug 8, 2009 | 09:10 PM
true dat yo.
t2t4 is in upwards of 1200
but its a badass transmission, and if you want badass...you pay badass.
i got a p2t4 from tigerjapanese.com when i got my complete swap.
Old Aug 8, 2009 | 11:25 PM
Tight R's Avatar
so regular h22 tranny it is..
where the 92-96 different gear ratio then the 97-01?
Old Aug 9, 2009 | 07:59 AM
prelude
M2A4 - JDM 4G
M2B4 - JDM 4G LSD
M2F4 - USDM 4G
M2U4 - JDM 5G Type-S ATTS/USDM Type-SH ATTS
M2Y4 - JDM/USDM 5G Base
M2Z4 - JDM 5G SiR S-Spec/JDM 5G w/ LSD option
Accord
P2T4- JDM Accord SI-R LSD(5g)
T2T4 - JDM Accord SiR-T (F20B) LSD
T2W4 - JDM Accord Euro-R LSD
U2Q7 - EDM Accord Type-R LSD
Added 2004/02/09 Full Gear Ratios
M2A4 - 3.307 - 1.950 - 1.360 - 1.071 - 0.787 - 4.266
M2B4 - 3.307 - 1.950 - 1.360 - 1.071 - 0.787 - 4.266 LSD
M2F4 - 3.307 - 1.950 - 1.360 - 1.071 - 0.870 - 4.266
M2U4 - 3.285 - 1.956 - 1.344 - 1.034 - 0.812 - 4.266 ATTS
M2Y4 - 3.285 - 1.956 - 1.344 - 1.034 - 0.812 - 4.266
M2Z4 - 3.285 - 1.956 - 1.344 - 1.034 - 0.812 - 4.266 LSD
Accord
T2T4 - 3.285 - 1.956 - 1.344 - 1.034 - 0.812 - 4.266 LSD
T2W4 - 3.285 - 2.090 - 1.481 - 1.071 - 0.812 - 4.266 LSD
U2Q7 - 3.285 - 2.090 - 1.481 - 1.071 - 0.870 - 4.266 LSD
Old Aug 9, 2009 | 09:08 AM
nus_dogg's Avatar
blah, I meant to put down T2T4 of course! LOL dang it, somehow I put down p. I didn't know there's a p2t4? lol good to know though.
Old Aug 9, 2009 | 09:35 PM
yes, apparently there was a non-lsd and lsd version of the p2t4...so all you kids with them, check to see if you got lucky.
Old Aug 10, 2009 | 03:38 AM
fatboy1185's Avatar
Big Cat
i paid 1100 for my f20b t2t4 tranny from hmotorsonline.com. IF i was you, i would get a usdm h22 tranny, and stick a mfactory lsd and aftermarket final drive in it.
Old Aug 13, 2016 | 03:01 PM
wesh22a4's Avatar
alnjdmautomotors.com hooked me up with a t2t4 trans for $950 free shipping
h22nate
Apr 29, 2010 09:45 AM
h22prelude99
Aug 2, 2007 01:54 AM
sloweredcivic
Oct 12, 2005 10:17 AM
wongf22b2
Jun 21, 2004 07:40 PM
JDMBB2
Nov 21, 2003 09:07 AM
