Fan Not Turning On and AC not working
Old Aug 7, 2009 | 09:33 PM
NteGSR2o9's Avatar
Default Fan Not Turning On and AC not working
1. My Radiator Fan does not work. I did the thermoswitch jump and it still wouldn't turn on, so that rules out the switch. The fan does work with it wired to the battery. I'm not trying to ghetto-rig it. Help me please. Also, I can't figure out where the relays on located.
2. My AC and Heater do not work. The climate control lights up. Is it the blower motor?
Old Aug 8, 2009 | 04:37 PM
NteGSR2o9's Avatar
Default Re: Fan Not Turning On and AC not working
up
Old Aug 8, 2009 | 04:41 PM
steveo135's Avatar
chances are you have a hole in one of the hard lines somewhere... when the ac is switched on does the compressor clutch engage?
Old Aug 10, 2009 | 07:48 AM
671M2S_DB8's Avatar
for ur radiator fan problem you might have a loose connection or ur relay is out.... the relay is in the front should have a bracket that has two relays together . to check if ur relay is bad just swap the plugs to see if the fan turns on.
Old Aug 30, 2010 | 09:24 PM
blackchoad's Avatar
i have the same problem.. i have a 1999 prelude and both my fans nor my a/c compressor turn on... any help? im not sure where the relays are located neither
Old Aug 31, 2010 | 04:44 AM
integra15's Avatar
Go through the troubleshooting section in the service manual. That will help you solve your problem.
Old Aug 31, 2010 | 12:04 PM
blackchoad's Avatar
thats another problem.. i dont have it
Blackbird435
Honda Civic (2001 - 2005)
Jun 12, 2013 08:50 AM
Balltongue0077
Feb 6, 2010 11:08 AM
duyfash0
Oct 8, 2008 06:46 PM
92spoonlude
Mar 31, 2007 03:29 PM
Siegfried
Feb 23, 2005 10:28 AM
