radio wiring
what up all. So i want to wire in a radio. currently i have no wires from the original wiring harness. i had to get a factory harness from the junk yard. so i have the factory harness, i know where to wire the constant but where can i tap into for the accessory? i have no cigarette lighter wires, and no clock wires. also, is there 2 different positions on the key tumbler for the accessory? is there a way i can wire the accessory to the first position, and is there a wire close by that gives voltage on the first position? thanks all
this should help
http://www.modifiedlife.com/car-ster...1-honda-civic/
the ign only power wire for the radio will have power when the car is in ACC and in the RUN position.
this should help
