Suspension & Brakes Theory, alignment, spring rates....
Gc/koni problem
Old Aug 7, 2009 | 12:31 PM
SlowEJ8's Avatar
Default Gc/koni problem
I get a light clunk when i go over a speed bump on my rear passenger suspension. I'm riding on gc's/konis, and i'm not sure what the problem could be, help pls.
Old Aug 7, 2009 | 12:40 PM
Egezzy's Avatar
Spongebrad Squarepants
Default Re: Gc/koni problem
how low do you have your car??
Old Aug 7, 2009 | 01:51 PM
myprotege's Avatar
If you don't know what the problem could be, why would you name the post "Gc/koni probelm"?
Old Aug 8, 2009 | 12:02 AM
SlowEJ8's Avatar
because it's a problem?
I actually have my rears pretty dumped... lots of tucking in the back... haha
Old Aug 8, 2009 | 03:30 AM
racebum's Avatar
Old Aug 8, 2009 | 07:33 AM
Egezzy's Avatar
then dont reply.
well your spring is probably unsettling then and your clunk is the spring becoming seated again.
Old Aug 8, 2009 | 12:53 PM
SlowEJ8's Avatar
is that normal though? do i need to raise it a little?
Old Aug 8, 2009 | 07:22 PM
gutted-dx's Avatar
Did you just install them?
Old Aug 9, 2009 | 02:21 AM
SlowEJ8's Avatar
Yes, i just installed them, and now its more of a problem, i'm sure its the suspensions because it didn't do this before.
It is now vibrating against something, usually when i back up , and still clunks when i go over a speed bump.
Old Aug 9, 2009 | 07:21 AM
gutted-dx's Avatar
Jack the up and check the tightness of the bolts and the condition of your bushings.
Old Aug 9, 2009 | 12:38 PM
SlowEJ8's Avatar
how do i check the condition of my bushings? and which bushings?
Actually theres something that i didn't tell you guys.
On my rear right side i believe its the lca? if not its the other bolt you take out to install the suspensions, is there suppose to be a nut to tighten the bolt? or is it just the bolt?
If thats the case, then that might be the problem, a missing nut. But It's the same on the left rear and it doesn't clunk or rattle.
allmotorlsbaby
Suspension & Brakes
Mar 6, 2009 07:04 PM
koulaid
Suspension & Brakes
10
Feb 13, 2009 02:49 PM
Rahjahdat
Honda Civic (2001 - 2005)
Sep 9, 2008 08:43 PM
SkaiWu
Jun 16, 2008 08:44 AM
4potnick
Suspension & Brakes
Mar 17, 2006 10:55 PM
