v-tec problems?
Old Aug 6, 2009 | 11:26 PM
9toes's Avatar
Default v-tec problems?
Ok so every once and awhile when i crack v-tec the check engine light comes on and when i come to a stop the idle is ruff for about ten seconds then goes away and if i turn the car off and turn it back on the check engine light is off and the car runs fine. I got the code checked and it was the v-tec solinoid "spelling?" i was told it could be an oil problem and might need a new oil pump but i wanted some more advise before i went and did that. and body know anthing of what im talki9ng about...
Old Aug 6, 2009 | 11:30 PM
Ruben19's Avatar
Default Re: v-tec problems?
try cleaning the vtec selinoid first.
Old Aug 6, 2009 | 11:31 PM
kccord's Avatar
How about checking the wires or getting another VTEC solenoid from the wrecker to see if it will fix the problem. Gee, replacing the oil pump if it's not broken is useless and expensive.
Old Aug 6, 2009 | 11:37 PM
9toes's Avatar
i cleaned the v-tec solenoid but it still does it and i havnt tested the wires yet, so i will do that as well and mabey replace the v-tec solenoid. how much does a oil pump run for a d series motor?
Old Aug 6, 2009 | 11:39 PM
CRXREFIC's Avatar
check the wiring its like 5-10 mins to go over the wiring not even....
btw not to thread jack this but the green plug on my wiring harness that goes to my vtec .... it wont go in all the way like its souppose to hook in right...? well this one wont hook in as u can just pull it out without unhooking that lil hook.... my vtec havent been working yet
Old Aug 6, 2009 | 11:50 PM
9toes's Avatar
yah i will take a look at it tomarow and as for yours you could probably find the v-tec wireing at a wrecking yard and swapit and see if it works.
Old Aug 7, 2009 | 01:26 AM
EKSiR99's Avatar
maybe a code reader can help to diagnose the problem
spoon quezada
Nov 7, 2013 09:12 AM
tuckin15s_8315
Sep 28, 2005 10:12 PM
kampucheakid
Jun 1, 2005 09:28 PM
gsrhatch530
Mar 28, 2002 01:36 PM
