96 DB7 4dr sunroof problems
Old Aug 6, 2009 | 09:49 PM
D15Bbigred's Avatar
Default 96 DB7 4dr sunroof problems
Well I hit the switch and it barely moves and the glass is basically sliding along the roof and has made huge gashes in the paint. Is there a write up anywhere on how you would even trouble shoot this ? My guess is it's either the motor or the cabling . That's the only two main components I can think of. Any help is greatly appreciated . Should I just try and get a whole nother assembly from a junkyard ?
Old Aug 7, 2009 | 12:59 PM
D15Bbigred's Avatar
Default Re: 96 DB7 4dr sunroof problems
no one eh ?
Old Aug 7, 2009 | 06:30 PM
KaBlookie's Avatar
if the glass is hitting the roof, then the glass is also not completely attached...might wanna look for things missing or broken.
might also help to take some close-up pics of the hinge/slider assemblies while the sunroof is open and post em up.
Old Aug 7, 2009 | 09:21 PM
samsyabi's Avatar
Yeah! There must be something broken or missing.
Old Aug 8, 2009 | 12:02 AM
spklsdb8's Avatar
I have the same issue and have been told from a honda tech to replace the hole thing. the gears that lift the glass up strip and was told once you take it apart you will never get it to go back together. dose yours leak water to?
Old Aug 10, 2009 | 01:05 AM
EnjoyTheRideDC2's Avatar
If it barely moves, its going to be the sunroof motor. If the glass portion wont lift up high enough in the first place to clear the roof, then the lifters need to be replaced.
If you can find a replacement for cheap, I say go for it. unless the motor and lifters ends up being cheaper overall.
Old Aug 10, 2009 | 01:41 AM
boarding2008's Avatar
Mine kinda does the same thing as well. My roof has a scrape on the passenger side. I pulled the fuse so I don't do it on accident(always had it open in my dc). So is the conclusion it has to be replaced as a whole? That blows if so :/
Old Aug 10, 2009 | 07:08 AM
No, you can buy the glass slide lifter from the dealer if yours is broken. If its not, then your sunroof frame might be loose or the slider needs to be reset and/or adjusted. The slider is the part the glass is bolted onto.
Old Aug 10, 2009 | 07:16 AM
Old Aug 10, 2009 | 08:38 AM
D15Bbigred's Avatar
sweet thnx dc2 . I think I'm going to just replace the whole thing. I found a replacement locally. Is their a step by step for this somewhere ? In all honesty I think straight up that its just the motor , because its still lifting just not enough.
Ej8_Travis
Aug 19, 2015 12:43 AM
RACEPAK
May 10, 2009 04:22 AM
MoogieBoogie
Mar 13, 2008 08:05 PM
whitemike1644
Jun 10, 2003 03:26 PM
Newbie In A Teg
Jan 16, 2002 12:32 PM
