will a b18c5 fit a 1996 civic ex?
Old Aug 6, 2009 | 07:57 PM
trung_akahondaluv'er's Avatar
Default will a b18c5 fit a 1996 civic ex?
will i was planning to swap my d16y8 for a b18c5 and i jus wanna kno will it fit or any b sereis engines will fit? i jus wanna kno which one? so i can swap it. and i wanna kno how my much will it all cost to switch and automatic change it to a manual?
Old Aug 6, 2009 | 08:01 PM
lsvtec97hatch's Avatar
Default Re: will a b18c5 fit a 1996 civic ex?
yeah of course but gotta get back support that hooks on to the motor mount engine and tranny for a 99-00 civic si, and some other things like axles etc....
Old Aug 6, 2009 | 08:06 PM
BrianFreels's Avatar
integra axles will work, you need to use yur stock engine harness, rear t mount off 99 si, im assuming since i used a 99 si block mount in my eg that the integra block mount will work for you, anyways, you need the transmission mount off your d16 transmission, you need the integra shift linkages, and a b series ecu, and you should be good, very simple swap
Old Aug 6, 2009 | 08:10 PM
98civdx's Avatar
Master Detailer
^^ no he needs the mount of a 99-00 si, integra mounts work in a eg not ek.
Old Aug 6, 2009 | 08:15 PM
true that
Old Aug 6, 2009 | 08:18 PM
ok well in my eg im running a 99 si block mount, so i figured that it would work all the same either way
Old Aug 6, 2009 | 08:20 PM
minus that stupid hook thing bolted onto the block mount, the bolted to the pillow mount, that ***** retarded, you must have the ball mount for it
Old Aug 7, 2009 | 09:29 AM
thanks but i also wanna know how much will it cost to swich from automatica to manual will cost?
Old Aug 7, 2009 | 09:53 AM
98civdx's Avatar
Master Detailer
on average 500+ but sence your going b series, you dont really need to buy anything besides the auto to manual conversion mount, pedles, clutch lines, master clynder.
if you dont go b you will, need, manual tranny, clutch flywheel, manual starter bolts and do the iacv fix, and a lil wiring will be needed for each. i suggest getting a manual engine harness.
Old Aug 7, 2009 | 10:52 AM
damn dis might take me a cuople years to do all dat cuh rite now im only 15 years old
Old Aug 7, 2009 | 10:53 AM
kaiba's Avatar
Yes it will fit.
PS. You don't need to change oil ever 1k miles on a R.
Old Aug 7, 2009 | 11:03 AM
EJ8freek's Avatar
Of course. With ease.
Old Aug 7, 2009 | 11:07 AM
JDM_SOHC's Avatar
lmao @ every 1k miles change the oil... i thought it was more like every 43 1/2 miles u should change it.. lol...
Old Aug 7, 2009 | 11:15 AM
Vindicator9000's Avatar
318 Curves, 11 miles
For real? Start saving. Do you have a job? Please don't tell me your parents are paying for this.
*mumblekidsthesedaysmumble*
B18C5/transmission - $3-4000 if you buy from hmotors
5 speed swap parts - $500
Other various replacement parts/fluids/etc - $200
Labor (if you don't swap it yourself) - $1-2000 unless you get a deal
Honestly, (and I know you won't listen because all 15 year olds know everything) you're better off without a fast car in high school.
I'm almost 30, and if I would have had the car I have now back then, I probably would be dead. I came close enough with a 20 year old 100HP grampa car.
There's no feeling in the world like doing a 720 on 6" of gravel at 80 mph, with a 4 foot deep ditch on either side of a one lane road.
Old Aug 7, 2009 | 11:30 AM
96DelSol's Avatar
Start saving up.
Old Aug 7, 2009 | 11:35 AM
Will? Oh FaSho!'s Avatar
this man speaks the truth
Old Aug 8, 2009 | 10:43 AM
im bout to work at bk and imma save up till im out of high skool...den imma get the parts and swap it
Old Aug 8, 2009 | 10:48 AM
slowhatchcali's Avatar
you should also get hooked on phonics! lol
Old Aug 8, 2009 | 10:52 AM
masuya_04's Avatar
until you can learn to stop speaking dog i will help you
Old Aug 8, 2009 | 11:01 AM
wannaBjdmca6's Avatar
do u knw how to drive stick?
Old Aug 8, 2009 | 11:05 AM
yeah i know how to drive a stick learn it from my friends and uncle
Old Aug 8, 2009 | 11:54 AM
you dont have to have an auto to manual mount for an ek, thats only for 92-95
Old Aug 8, 2009 | 11:57 AM
well mines a 96 right now i only got a d16y8 motor in in it
Old Aug 8, 2009 | 12:40 PM
FlewByU352's Avatar
its so funny seeing people that even after having a manual car for so long still cant drive it. Taking off and especially parking just riding the clutch and non stop revving haha and it kills me that people dont rev match when downshifting you just watch the car jerk and the front end flop down. and then slowing down they push in the clutch pedal and just hit the brake. I engine brake and heel toe downshift all the time I hardly ever have to use much force on my brake pedal. it takes time to learn but people that have been doing it for a year or so and goon it up just facepalm. anyways i'm looking to do the same swap and I have the same car model and year so this thread could be very usefull.
Old Aug 8, 2009 | 01:16 PM
TorquelessEM1's Avatar
Look at your sig,and learn how to spell VTEC before you do anything to your car.
