throwing codes ecu
po 715, po 113, and po 700. i know that my vss turbine speedsensor is bad. can you fix thoes or do you simply need to replace? its a circut code, so does that mean the sensor is no good or is it the computer?
try the sticky at the top of the forum marked "ENGINE SWAP INFO & FAQs,HOW-TO CK ENGINE LIGHTS "
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/engine-swap-info-faqs-how-ck-engine-lights-878010/
which will take you here --> https://honda-tech.com/forums/tech-misc-15/heres-list-obd2-codes-if-anyone-cares-466877/
P0715 - ????
P0113 Intake Air Temperature (IAT) Sensor Circuit High Voltage - the IAT line is shorted to battery or not plugged in correctly. (plugs swapped??)
P0700 Automatic Transmission Control System - could be anything with the trans.
googled it, this may help you... http://autorepair.about.com/library/faqs/bl282f.htm
P0715 - ????
