mini me help
Old Aug 6, 2009 | 12:35 PM
sh!ft's Avatar
Who the fack changed my title?!
Default mini me help
so i just put a b7 block and y8 head combo togeather using arp's and dropped it into the 98 4 door. for some reason it has spark and fuel is going to the rail but no fire, just a few small sputters here and there. any ideas
Old Aug 6, 2009 | 01:11 PM
sp00ledbseries's Avatar
Default Re: mini me help
What ecu are you using are you sure your injector clips are plugged in right. Are you leaking fuel any where. Did you check the injector o rings
Old Aug 6, 2009 | 04:06 PM
sh!ft's Avatar
it was the spark plug firing order, they were mixed up at the dizzy. but now for some reason, the car wont go any where unless my foot is all the way down to the floor on the gas pedal. and it takes off REALLY SLOWLY untill about 4k then runs smooth all the way past that. im not really sure what thats about gotta look into it more later on
ALSO the gauge cluster(auto) is showing the D4 position as a flashing green square around it. any idea what thats about???
Old Aug 29, 2009 | 08:23 PM
94civic96's Avatar
well i thought that 98's had knoch sensors and crankshaft position sensor but the b7 has neither if you running a 98 ecu i dont know how the car is running but id look into that
NevinJoe
Sep 17, 2025 12:50 PM
TeG cRaZy
Jul 17, 2012 10:09 PM
recycled air 90
Jul 9, 2008 07:47 PM
HBK
Nov 9, 2004 05:18 AM
Kamin
Aug 3, 2002 12:08 PM
