Selling everything from my monster turbo build up! Alot of stuff here!
-Stage 5 Ported and Polished LS Head, Black Nitrate SS Oversized Valves, Titanium Springs/Retainers, Bronze Guides, Skunk 2 Cam Gears, This head will make alot of power. vtec what?
$900 SOLD
-LS Tranny with quaife (The tranny has just been gone through and the only gear/syncros that needed to be replaced was second gear which was done, all the other gears were fine. They also replaced a seal that needed done) So basically the tranny is brand new. It has zero miles on it since the work was done. $1400
-Custom Grind Web Cams (Josh/Boosted3g made 530whp with these) $350 SOLD
-Skunk2 Red Cam Gears, Brand New $180 SOLD
-Spearco 28 x 7.5 x 3.5 Custom Build Intercooler (Perfect for cars over 400hp and it fits without cutting the bumper support in anyway) $670
-GM 3Bar map sensor $60 SOLD
-MSD Ignition 6al $125 SOLD
-MSD Coil $18 SOLD
-MSD Distributor Cap $20
-AEM EMS for OBD1 Honda/Acura (Brand new) $1100
-ES Motor Mounts (Brand new in box) $30 SOLD
-B&M Short Shifter (New) $125 SOLD
-Apexi Air filter (New) $65 SOLD
-AEM Fuel Pressure Regulator Silver (New) $125 SOLD
-AEM Fuel Rail Silver with VDO fuel pressure gauge $125
-MSD 720lb-750cc Injectors $350 SOLD
-GSR Oil Pump (Bigger Gears, a must for turbo cars!!) *Cryotreated* $60 STOLEN
-Autometer Oil Pressure Gauge Phantom Face (New) $50 SOLD
-B&M Oil cooler *just cooler* $40 shipped SOLD
-Oil Filter Relocator Kit (New) $40 shipped
-Turbonetics TO4E-54 stage 3 wheel with .82 AR $375 20K miles
-MSD Plug Wires Red $40 shipped
-Thermal 3" Turbo exhaust with stealth added $400 plus shipping
Email, AIM, or PM me on here for more details
[Modified by DamonBoost, 2:37 PM 8/29/2002]
[Modified by DamonBoost, 7:03 PM 8/29/2002]
[Modified by DamonBoost, 7:37 PM 8/29/2002]
$900 SOLD -LS Tranny with quaife (The tranny has just been gone through and the only gear/syncros that needed to be replaced was second gear which was done, all the other gears were fine. They also replaced a seal that needed done) So basically the tranny is brand new. It has zero miles on it since the work was done. $1400
-MSD Coil $18 SOLD
so the intake side on the turbo is .82 but whats the exhaust side trim? whats the condition as far as shaft play and seals?
Some questions:
1. Is the oil pressure gauge electric of mechanical? If its electric it comes with sender, right?Edit: its electric with sender.
2. Which model of MSD coil? Edit: Blaster 2
3. What engines will the GSR pump swap into? Edit: B series
4. I assume the MSD 6al is already "cut" for 4 cylinder use, true? Edit: True. 4 cylinder only.
Randy
Answers I got from e-mail.
BTW-I e-mailed you about the coil.
[Modified by RGAZ, 1:15 PM 8/27/2002]
Randy
Can anyone (DamonBoost?) confirm if the AEM fuel rail will fit on a first gen B16 intake manifold? I'm unclear on this after looking at AEM's application list on their website.
Damon, can you answer my question, or no? If I can confirm the fuel rail fits, I'll take it! BTW, whos the girl in your avatar pic? <--
I have no idea if it will fit? Maybe post in the civic forum and I am sure someone could help you there with it. Sorry. The girl in the avatar is Claire. My interest at the moment.
do u still have the stock regulator on the AEM fuel rail?
or will the stock one fit?
where is the fpgauge located on the rail?
just more info on that part? im interested on it. thanks...
How is the idle on the cams?
[Modified by Speed PHreak, 8:02 PM 8/27/2002]
What car is the Thermal off of? Is it already pre-assembled and how many miles are on it?
why u sellin?! dont do it, man!!
im interested in the MSD wires. ill send you an IM.
[Modified by dlplayboy, 12:09 PM 8/28/2002]
