D17a1 swap
Ive read your Faqs.Searched google and HT. Im eyeing a 91 civic body and was wondering if i can put my 2004 D17a1 into it, i understand the wiring and obd differnece, this is just for reliablity not racing. Nay yay? im sure what id have to spend to get it to work i could rebuild the damaged engine,or replace with a dohc. but thats what im here to learn.
imo its really not worth it. It would be real close to the difficulty of a k series swap. Plus very little aftermarket support i know of in terms of swappin it.
D17A1
- Found in:
- 2001-2005 Honda Civic DX/LX/VP
- Displacement : 1,668 cc (101.8 cu in)
- Bore and Stroke : 75 mm × 94.4 mm (3.0 in × 3.7 in)
- Compression : 9.5:1
- Power : 115 hp (85.8 kW, 117 ps) @ 6100 rpm
- Torque : 110 ft·lbf (15.2 kg/m, 149 Nm) @ 4500 rpm
- Valvetrain : SOHC (4 valves per cylinder)
- Fuel Control : OBD-2 MPFI cut: 180kmh
- Not worth all that trouble with wiring and making your own custom mounts just for 115hp...Get yourself a D16Y7 or D16A6 if your want a basic swap with reliability or if you have the knowledge rebuild your stock engine
thanks guys its just that this engine only has 15k miles on it, i put it in a year ago and just have gotten bored with this civic, keep braking bolts and suspension parts. car is too heavy!
just thought it be cool to have a Ef putting around with my new engine. thanks.
nate24740
Honda Civic (2001 - 2005)
22
May 18, 2009 10:24 AM
