Transmission & Drivetrain Gearboxes, Differentials, Clutches
OBX+gsr tranny=help
Old Aug 5, 2009 | 05:53 PM
poppypizza's Avatar
Default OBX+gsr tranny=help
Im installing a obx lsd in my gsr tranny and i swapped bearings and ring gear and speedo gear and when I put everything together and tighten everything down, the drive-shaft wont spin nor will the transmission shift however when i loosen the bolts the drive-shaft will spin. i did the c clip also,, i have put it together 3 times and the same thing every-time. Does anyone have any idea at all??? does something need to be trimmed down i searched and haven't found anyone with this problem,, ANY help at all would be greatly appreciated.
Old Aug 5, 2009 | 06:17 PM
Mista Bone's Avatar
D Tranny Guru
Default Re: OBX+gsr tranny=help
Shims, gotta check the clearance per the manual.
Hopefully you didn't ruin the bearings or crack the case.
Old Aug 5, 2009 | 06:24 PM
poppypizza's Avatar
What shims should i be looking at?
kellerscobra
Aug 2, 2018 02:11 PM
NoXqcsMotosport
May 22, 2013 02:22 PM
AaronDavis
Feb 17, 2012 02:32 PM
Brian_92GSR
Mar 7, 2002 01:21 PM
