NY FS: 2002 WRX Hudson Valley, NY - $9000
Old Aug 5, 2009 | 03:17 PM
crx(gator)'s Avatar
Default FS: 2002 WRX Hudson Valley, NY - $9000
I purchased the car from the original owner who did pretty much all the mods.
113k miles
Sedona Red Pearl
5 speed
no accidents
JF1GD29612G503963
$8000
There has been a lot of recent maintenance done. Within the last 12kmi car has received new timing belt, tensioner, front main seal, oil pump o-ring, all idler pulleys, front endlinks, front calipers, rotors, clutch, flywheel, pressure plate, throwout bearing, trans. mount, top mount intercooler and countless number of misc. nuts, bolts, vacuum hoses, brackets, t-bolt clamps. I just did a tune-up as well - plugs, fuel filter, pcv, air filter. -
Mods
Engine
VF34
STi pink injectors
STi intercooler
Invidia UP
Helix v3 DP
Maddad 3" - 2.5" midpipe
STi muffler
Samco TB hose
Grimmspeed EBCS
Professionally tuned - prior tune before the GS EBCS made 267 whp / 270 ft/lbs
Drivetrain
STi 3 puck clutch
STi Pressure Plate
Lightweight flywheel
Group N Engine mounts
Group N Transmission mount
Short shifter
Cusco shift bushings
Suspension/Brakes
Whiteline rsb
whiteline rear endlinks
05 Legacy GT Front brakes
H6 rear disks
REAL Prodrive P1's - no Rota garbage
Exterior/Interior
Genuine Subaru oem front lip
urethane ww rear lip
STi side marker
STi front grill
Painted Side Skirts
04 wrx seats front and rear and black doorcards
05 WRX 6-CD changer
Bad
The car is daily driven and has over 100k so there are some dings, scratches and so forth. However, the paint really shines and looks great. The car makes a bit of a clunk from the front for some reason. I had it checked out and the tie rods, ball joints and wheel bearings are all in good shape, so it may be the control arm bushing. There is also a noise coming from the center console around 3500 rpm - sounds like it's from the transmission but im told it's not and that it's the exhaust rattling from the mechanic that also checked out the suspension and installed the motor mounts.
Overall this is a fun car and I used it to go back and forth to school. Only selling it because I am looking into buying a house now.
Old Aug 6, 2009 | 06:32 AM
crx(gator)'s Avatar
Default Re: FS: 2002 WRX Hudson Valley, NY - $9000
bump...
Old Aug 6, 2009 | 01:40 PM
cubanxpress029's Avatar
man love that color thats a clean car
Old Aug 6, 2009 | 05:30 PM
crx(gator)'s Avatar
bump, bought a car today, NO TRADES.
Old Aug 8, 2009 | 06:07 AM
crx(gator)'s Avatar
bump...
Old Aug 8, 2009 | 05:40 PM
crx(gator)'s Avatar
bump...
no your b16a swapped civic + $1k does not = a well modded wrx...
stupid *** honda owners...
Old Aug 8, 2009 | 05:46 PM
srt4mike's Avatar
Old Sep 13, 2009 | 02:57 PM
accord_raffi's Avatar
i'm assuming this is sold now?
fminusmic
Nov 8, 2018 09:44 PM
stevieteg
16
Oct 2, 2008 02:55 PM
st0nedstoopid
Mar 8, 2006 06:41 AM
st0nedstoopid
Jan 19, 2006 08:28 AM
