1997 Accord SE Drivers window trouble
Old Aug 5, 2009 | 03:13 PM
doitmyself's Avatar
New User
Icon2 1997 Accord SE Drivers window trouble
Followed the instructions I found on here to take the door panel off (thank you so much for those!!). I have the panel off and the door switch works and you can hear the motor working but the window doesn't move. It actually sounds like there's something grinding on the glass. I can pull the window up by hand to within about 4 inches of the top but it won't stay up. I'm not quite sure what could be bad. The switch works, the motor works - please help!! Thanks!
Old Aug 5, 2009 | 04:17 PM
alkoholikwun's Avatar
Default Re: 1997 Accord SE Drivers window trouble
its usually never the switch but the motor, the motor is probably going out. i'd just grab a new motor/regulator from the JY. easy to replace.
Old Aug 5, 2009 | 04:37 PM
doitmyself's Avatar
New User
Icon2 Re: 1997 Accord SE Drivers window trouble
Thanks for the info - new to this.......what is the JY?
Old Aug 5, 2009 | 06:47 PM
Targa250R's Avatar
be professional
JY = junkyard . . .
It's most likely that the regulator cable became jammed or kinked. The cable is an intergal part of the regulator and cannot be purchased separately or disassembled. You will need a regulator, which can either be purchased new or pulled from a car in a salvage yard.
Check the rubber run channel for kinks and snag points as well. If the channel is damaged, replace it with a new one while you're in there. Yes, they're expensive ($72+), but if you put it all back together with a bad run channel, you're going to continue having problems. I don't recommend installing used run channels because the rubber is usually hardened/cracked/kinked or otherwise faulty.
Make sure to lube the run channel with Shin-Etsu grease or silicone spray.
aresjay
Oct 17, 2018 01:36 PM
cupton50
Mar 15, 2014 03:16 AM
jdadams12
Oct 12, 2006 09:15 AM
Edgemingsr
Jun 2, 2004 10:08 PM
JL 74
May 21, 2004 01:09 PM
