95 Civic CX d16z6 emissions help.
Replaced and checked:
Magnaflow Cat
NGK Plugs and Wires, gapped and model #'s listed on timing cover.
OEM Japan Cap/Rotor
Oil/Filter change.
Timing is spot on now.
o2 sensor tests as being good and working.
Test Results:
HC 0.81 FAIL, pass is 0.80
CO 15.34 FAIL, pass is 12
NOX 0.52 PASS, pass is 2
This test was run without denatured alcohol and using 87 octane fuel. I'm not sure why this car is still not passing the emissions test but I'm thinking either the fuel injectors are leaking fuel or I should be using 91 octane fuel which is the highest we have around here at normal gas stations.
Any suggestions please? Girlfriend needs the car for work and we have no more temporary plates we can buy from the DMV.
Magnaflow Cat
OEM Japan Cap/Rotor
Oil/Filter change.
Test Results:
Oh, the cat was put on today because we had some shitty ebay one that was sold with the car when she bought it. They said it should pass with the new cat because the numbers were previously within HC .89 to 1.7 and CO from 12.45 to 16.1. And NOX was still passing but around 1 to 1.76.
So the new cat def. helped but didn't get it all the way there.
Any CEL?
Did you check the ignition timing with a timing gun and the service connector jumped? Is the valve clearance set to spec?
Is the fuel pressure a little high? Is the FPR working?
Ignition timing was done with a timing gun and service connector jumped. Valve clearance, no clue.. never done that one before nor would I trust myself.
Fuel pressure, no clue.. regulator.. no clue. Might be time to take it to a mechanic. Tried doing everything I could myself..
Don't really have the money for anything anymore lol :\
NO CELs
it seems like a fuel issue, but what was the O2 reading from the emissions sheet???
check your injectors, it seems they are probably leaking
how many miles on the engine? could be getting blow-by in the cylinders due to worn cylinders/rings........
The motor swap was done by the previous owner who was some 40-50 yr old man. He claims the motor only had 35k when installed, which would mean it has 45k now.
He did say that the fuel pump is the original fuel pump and the car has 210k miles on the chassis now. I'm wondering if the fuel pump is going bad and causing the car to lean out.
It's interesting because the car has a CX tranny and I figured it would get at least 40 mpg but it gets closer to 30-35 mpg with mainly highway driving.
some auto-parts stores rent tools, its not expensive, comes with everything you need and instructions on how to use it on your vehicle........
I know most of them are not mechanics, but sometimes the computer gives you a list of possible causes, does your sheet have any other info, or did the emissions inspector tell you anything???
I would start with fuel pressure, and injectors.......
Nah thats the only info AZ sheets give. And the emissions station people are only good for testing, they havent really said much else.
We have a mechanic who lives next door and I guess we might just take it over to his shop because they have emissions testing equipment there and can look it over.
roldan1986
10
Mar 15, 2016 12:52 PM
ariethekid
32
May 17, 2013 03:37 AM
Cataclysmic
19
Jul 31, 2009 12:38 PM
