Honda S2000 Honda S2000
need help with headlights
Old Aug 5, 2009 | 12:48 PM
Mr Marcin's Avatar
Default need help with headlights
hey guys i bought a ap1 a couple weeks ago, its a 01. the last night i get into my car and turn on my headlights.. and i noticed that my driver side headlight is lighting up a pink color. mean while the passenger side is white/blue. i turn the lights off and turn them back on...when they first turn on its fine, but as the light warms up fully it turns pink. WTF?!? has anyone had this problem before?
Old Aug 5, 2009 | 01:25 PM
kleen98accord's Avatar
Default Re: need help with headlights
uhhh maybe the previous owner changed the bulb, something probably around the 14000k temp range.
Old Aug 6, 2009 | 04:16 AM
White Smoke's Avatar
i my honda
Global Mod
Yeah, sounds like you have miss matched bulbs. I've never hear of one turning pink on it's own.
Old Aug 6, 2009 | 08:34 AM
Mr Marcin's Avatar
for the past two months they have been blue. ive been looking on tons of fourms and one person said that the bulb is on its way out and i should buy two new bulbs. but i looked on majestic honda and they are 200 a piece :/
Old Aug 6, 2009 | 08:46 AM
Zaakro's Avatar
it could be that the bulb is going or the ballast can't ignite the bulb fully
Old Aug 6, 2009 | 09:07 AM
Sub2k's Avatar
sounds like your bulb change that first they are cheap but id recommend changing in pairs
Old Aug 6, 2009 | 09:11 AM
Black S2K's Avatar
i need help finding mines too after i crashed im missing both dont know where they ended up
Old Aug 6, 2009 | 10:58 AM
Sub2k's Avatar
what are you missing your ballast ?? if you take your bumper off they are right under the headlights
Old Aug 6, 2009 | 01:18 PM
bigmacnfries's Avatar
you crashed??
Old Aug 7, 2009 | 07:41 AM
TPhong's Avatar
^ X2
Old Aug 7, 2009 | 07:56 AM
Mr Marcin's Avatar
thanks for the imput. on another note i took my car out last night again and the headlight that was burning pink....doesnt light up at all now :/..it flickered for a second and went out
Old Aug 10, 2009 | 06:46 PM
R Legend's Avatar
Looks like it may have been a cheaper replacement that was on its way out. I always replaced both bulbs together just to eliminate any variations in color. They are a little pricey, but oem is the best option IMO
Old Aug 11, 2009 | 07:27 AM
i my honda
Global Mod
No need to pay OEM prices. 200$ a bulb is straight retarded! Just pick up some D2S bulbs of your choice. I always recommend a quality brand like Sylvania, PIAA, Philips, or Stanly.
Old Aug 11, 2009 | 09:04 AM
Mr Marcin's Avatar
thanks for the info guys...now my question is how hard is it to change the bulbs? im new to s2000's
Old Aug 11, 2009 | 12:59 PM
honda1234567's Avatar
check your bulb
_________________________________
$29 auto insurance for Honda
@ http://www.localdiscountautoinsurance.com/
I guarantee this will help you save a lot of money.
Old Aug 11, 2009 | 02:43 PM
R Legend's Avatar
Originally Posted by White Smoke
No need to pay OEM prices. 200$ a bulb is straight retarded! Just pick up some D2S bulbs of your choice. I always recommend a quality brand like Sylvania, PIAA, or Stanly.
I do tend to forget about my discount.
Old Aug 11, 2009 | 05:29 PM
Mr Marcin's Avatar
how much of a discount
Old Aug 12, 2009 | 04:17 AM
i my honda
Global Mod
You can buy the same bulb the dealer sells from a Stanly (I believe) dealer for MUCH less. Don't wast your $$ on the Honda markup dude. Even with the a discount I am sure it will not be cheaper then buying direct.
Old Aug 12, 2009 | 07:31 AM
Mr Marcin's Avatar
ok..i was looking at aftermarket ones...does anyone know what the stock bulbs burn at? 6k? 8?
Old Aug 12, 2009 | 08:02 AM
Sub2k's Avatar
6k-8k is just the color basically the higher you go the less light you have i have 6ks and they look pretty good. why dont you take out your bulb thats working and swap it in to your other housijng to make sure its not your balast.
changing the bulbs in the s isn't the easiest of cars you have to pull down your liners in your front fenders i took my rims of as well it helped alot as its a cramped spot to work in.
you also need a special tool to open the housing ill see if i can find what it was called again.
Old Aug 12, 2009 | 08:06 AM
Mr Marcin's Avatar
thanks..hopefully i can get it up on my friends lift tonight and switch the bulbs around. and if you can find out the tool it would be great cause one of my friends said it was a torx t25. i just want to make sure
Old Aug 12, 2009 | 08:49 AM
Mr Marcin's Avatar
i found these http://www.hidconcept.com/Bulbs-philips4k-d2s.html or ?
Old Aug 12, 2009 | 07:36 PM
Mr Marcin's Avatar
anyone?
Old Aug 13, 2009 | 05:45 AM
i my honda
Global Mod
Philips makes good bulbs, but if it were me I would probably go up a bit in temperature. I do not know what the factory bulbs temp is.
Old Aug 13, 2009 | 06:36 AM
Mr Marcin's Avatar
every where i look 4300 is the stock temperature..and i want to look as stock as possible
